In-Line Twin Motor
I have now completed making te extra long shaft for my in-line twin electric motor. This shaft allows me to assemble two 7Kw motors into a single unit but also allows me to use 2 seperate speed controllers. The shaft is quite complicated as it has to have the 2 groves for circlips and 8 flats for the drive areas.
- IMG_2705.JPG (45.99 KiB) Viewed 15654 times
The reason I am running 2 seperate 7Kw motors on a single shaft is so that I can use 2 seperate speed controllers, one for each. By doing this I can double up on current without getting excessive, keeping cable sizes smaller and lossess lower. So I will be running 280amps continuous and peak up to 400amps. This is however split into 2 lots of 140amps continuous and 200amps peak. I am using esc's capable of 200amp continuous. Using 12 cell LiPo at 50 volts full charge gives 50x140=7000watts continuous and 50x200=10,000watts peak....alll of course doubled up to give 14,000watts (18.7hp) continuous and 20,000watts (26.7hp) peak.
Here they are now set up with the esc's all wired up and connected:
- IMG_2704.JPG (52.57 KiB) Viewed 15654 times
I have only connected one 'bank' of batteries for the purpose of testing - that is 12 cell 5amp.hour.
There is no prop driver yet as I need to machine one up, much bigger than the one supplied with a single motor. I have ordered the 54mm diamter aluminum bar needed for this and am waiting for it to arrive.
My plane is sponsored by HobbyKing as it will be one of the largest single prop electric planes world-wide. I have just received the HobbyKing Turnigy batteries - all 24 of them!
So I know have 12 cell 30amp.hour or 12 cell 15a.hr for each motor. Since each motor also runs on 3 banks of batteries, each bank of batteries only has to supply 1/3 of the current, which will be 46amps continuous or 66amps peak. I already run these batteries on planes that take over 100amps continuous so I know these will be fine.
