ziroli c47 build
David Jones
Re: ziroli c47 build
Postby David Jones » June 28th, 2013, 10:37 am
Hi Paul, the tail cone and the tailplane fairings are soft balsa sheet and block. I find it best to stick them on and then carve / sand to shape in situ. The beauty is, if you mess up, you can just rip it off and start again. The wing mounting blocks in the fuse were scrapped. I made up 1/8" full depth ply doublers for the wing seats, slots were cut and 2" wide 1/4" ply plates were inserted and reinforced with balsa triangle. The wing blocks in the centre section were replaced with 1/4" ply plates flush with the bottom of the ribs then sheeted over. Balsa block was then added to infil up to the top of the ribs and then sheeted over. When completed, the full wing assembly was placed on the fuse and aligned up, 1/8" pilot holes were then drilled through the centre section and cross plates in the fuse. These were then drilled out to 6mm and captive "T" nuts were fitted. I've attached a couple of pictures for you, its all pretty much explained in my build thread. By the way, I do like lights, I will deffo be looking at doing something similar to your set up...very impressive. Jonesey.
Dakota build 117 (Medium).jpg (37.6 KiB) Viewed 19027 times
Dakota build 095 (Medium).jpg (48.15 KiB) Viewed 19027 times
Dakota build 055 (Medium).jpg (35.47 KiB) Viewed 19027 times
paul smith
Postby paul smith » June 28th, 2013, 9:45 pm
Hi Dave
wow thanks for the info, that's a really great shaping job
thanks for the ref pics ill get onto that next, after I attach the tail section over the weekend
if you want I can make you 4 leds on wires to a 3v supply if you need your lighting to be 4 way like mine
let me know
good luck for the taxing tomorrow
Paul
Postby Alan Cantwell 1131 » June 28th, 2013, 10:14 pm
dont know if you have noticed, by the way, but Daves tail halves are removable, neat little tube and joiner job,
paul smith
Postby paul smith » June 29th, 2013, 6:59 am
Hi Alan
yes I wish I had of thought of that
its always the way when you've finished that bit
I might do that for my next ziroli dak lol ;)
David Jones
Postby David Jones » August 16th, 2013, 9:35 am
Hi Paul, sorry to see you are selling the model, it's looking really nice. If the price on the for sale section is correct, its an absolute give away. Mine had its six proving flights at Elvington last weekend, flew like a dream straight off the board. I hope whoever buys it from you has the same success. Dave Jones.
Joshua Henderson
Postby Joshua Henderson » August 18th, 2013, 8:11 am
Hi guys
Just to let you all know that I will be getting this dc3.
Hopefully it will be being taken to gaydon for me.
It will most likely be finished by my grandad as I have a lot on but I will get as many pics as possible.
Josh
Joshua Henderson
Postby Joshua Henderson » August 29th, 2014, 8:51 pm
Bump, joined the LMA and registered the model today.
Work will be started in the next week or so after the inspection.
I will update this thread as and when there's progress.
paul smith
Postby paul smith » August 29th, 2014, 9:46 pm
nice one
Joshua Henderson
Postby Joshua Henderson » September 7th, 2014, 7:00 pm
Hi everyone,
Just a quick update, the model is being built by a club mate for me at the minute as I'm short on time etc.
Sheeting has started on the fuselage.
A couple of notes on the model.
The model will be going electric, with a possible sound system.
I have a new tail plane, fin elevator and rudder kit.
The tail plane will have removable halves.
I'm also after some wheels if anyone has any as one of the ones I have is
Damaged.
Joshua Henderson
Postby Joshua Henderson » September 7th, 2014, 7:05 pm
Here's a couple of pics
Joshua Henderson
Postby Joshua Henderson » September 7th, 2014, 7:06 pm
paul smith
Postby paul smith » September 7th, 2014, 7:57 pm
ah there she is lol keep up the good work
Joshua Henderson
Postby Joshua Henderson » September 17th, 2014, 10:00 am
Hi everyone
Just another quick update.
It's looking really good. Allen is doing a lovely job of the build for me.
Josh
Joshua Henderson
Postby Joshua Henderson » September 17th, 2014, 10:01 am
Here's another
Joshua Henderson
Postby Joshua Henderson » September 19th, 2014, 3:31 pm
A bit more progress
Joshua Henderson
Postby Joshua Henderson » October 4th, 2014, 4:22 pm
A bit more progress
Joshua Henderson
Postby Joshua Henderson » October 7th, 2016, 8:30 pm
Hi everyone
It's had new outer wing panels and ailerons built.
New tail and fin and elevators and rudder.
It will be coming out in the next few weeks to be continued as I haven't touched it for 7 or 8 months
Joshua Henderson
Postby Joshua Henderson » October 7th, 2016, 8:33 pm
It needs centre section sheeting underneath
Tail cone
Nacelles sheeting
Sand all the fus
Is there anyone who can glass/ detail the model local to blackburn lancs as I'm allergic to the resins?
Users browsing this forum: No registered users and 76 guests
