Postby David Jones » January 5th, 2014, 10:22 am
I've made a start on detailing the model now that it is all primed, filled and rubbed down. I've never done this sort of thing before, always thought it was too fiddley and time consuming but, having taken some advice (thanks Phil at Fighteraces), and had ago at it, I'm totaly hooked. I started off by drawing the panel lines on in fine pencil and then measured off every 1/4" for each rivet (I didn't want to chance my luck at getting them evenly spaced on my first attempt). There will be a line of rivets along both sides of the panel lines.
1/64" panel line tape was then stuck on and sprayed over with primer. Once dry, the primer was lightly rubbed back and the tape removed, leaving a very fine channel. The rivets (white PVA glue) were then added, using a small applicator bottle and fine nozzle. They don't stand out much at the moment but I'm sure they will be clearly visible when the final colour is added. So far I've done the tailplanes, the wing panels, centre section and cowls. There are 936 rivets on each tailplane half, so there's going to be a fair few on the model by the time I'm finished.
It's taken me more time to mark out where the rivets go than it has to actually apply them. I've found that once you get into a rhythm the process is quite theraputic and a good "stress buster". I've attached a couple of photos of my progress so far, next up will be the fuselage, which I'm hoping to have done by the end of the week.
- Copy of Dak pictures 032.jpg (37.94 KiB) Viewed 15694 times
- Copy of Dak pictures 039.jpg (24.26 KiB) Viewed 15694 times
- Copy of Dak pictures 040.jpg (33.07 KiB) Viewed 15694 times
