Wellington build and re-build
Peter Siggins
Re: Wellington build thread
Postby Peter Siggins » March 1st, 2016, 5:38 pm
Hi Dave ,
I tried Flitehook for some excellent pins - out of stock at the moment but worth a shot.
Steve I do like the look of what you're doing - just a question I didn't know the tail feathers had the strips on as well? By the way it takes a serious amount of solartex to cover it.
Pete
Steve Vodrey
Postby Steve Vodrey » March 2nd, 2016, 7:32 pm
Hi Pete.
The tail has similar strips to represent the geodetic structure. Once again I can't really be bothered to do the underside although I did make the effort to do both sides of the fin...
I got 20 metres of solartex so hopefully that's enough.
Steve Vodrey
Postby Steve Vodrey » March 10th, 2016, 10:44 am
After yet more time doing last bits of preparation before covering I took the lounge over and set about starting the covering last night.
The open structure lends itself well to solartex so several hours later the fuselage is about done.
Covered Fuz.jpg (30.14 KiB) Viewed 41029 times
To prevent the covering getting saggy in the sunshine I may well give the whole thing a spray with thinned down some cellulose dope.
Karl mander
Postby Karl mander » March 12th, 2016, 12:38 pm
Very nice, at this increased rate of construction she may have her maiden flight before 2020! :D
Jason Griffiths
Postby Jason Griffiths » March 19th, 2016, 7:46 am
Steve - Looking very nice .
Thanks 8-)
Steve Vodrey
Postby Steve Vodrey » March 26th, 2016, 7:42 pm
Before finishing the covering it was time to set up the direction of the elevator servos as reversing one of them is not an option as they would both be reversed so best to get them moving in the same direction. Same applies to the four flap servos but not the ailerons of course. This makes it possible to use a six and seven channel receiver to operate the 13 servos needed thereby avoiding the extra cost of 8 and 14 channel receivers
Elevator servos set up.jpg (72.74 KiB) Viewed 40719 times
Well that's the covering done. The geodetic effect looks ok after all the tedious work involved.
Finished covering.jpg (63.02 KiB) Viewed 40719 times
Time to do some spray painting tomorrow. My local car paint supplier kindly mixed the base colours for me in cellulose.
paul needham
Postby paul needham » March 28th, 2016, 10:41 am
Aye up Steve, how do you get away with building the welly in the living room ? Looking good mate.
Postby Alan Cantwell 1131 » March 28th, 2016, 1:29 pm
Could be a pair of wellies! Looking good Steve
Steve Vodrey
Postby Steve Vodrey » March 29th, 2016, 7:34 am
Thanks gents.
Busy spray painting at the moment and building the front gunner. I wasn't going to make it until test flights were done but being the optimistic type best to make the proper job than waste time on a temporary lash up just to cover the hole at the front...
Steve Rickett 2333
Postby Steve Rickett 2333 » March 29th, 2016, 2:49 pm
Nice and tidy!
Jason Griffiths
Postby Jason Griffiths » March 30th, 2016, 6:32 am
Looking Good .
Thanks 8-)
Steve Vodrey
Postby Steve Vodrey » March 31st, 2016, 7:51 am
The bit that counts is the painting which never goes to plan. Anyway after getting some low tack tape I spent several hours masking off the black bits that I had done over the weekend.
Masked fuz.jpg (30.67 KiB) Viewed 40469 times
The brown soon went on all over so I can put the green on later after I have a proper idea of the pattern...
Painted wing.jpg (29.71 KiB) Viewed 40469 times
Just a bit foggy in the garage. I do use a mask but i'm glad I don't do too much spraying...
Steve Vodrey
Postby Steve Vodrey » April 2nd, 2016, 9:12 am
The night black was also a special mix and according to the paint shop has green and all sorts in it. Not that it can be seen.
black bits.jpg (47.24 KiB) Viewed 40368 times
The camp needed to be blown in so I used my badger airbrush for this. After spending most of yesterday getting it to behave it started to work properly and all was done.
Postby Dave Parry » April 2nd, 2016, 12:46 pm
Looking fantastic Steve, another great build thread I have enjoyed watching. If you ever feel the need to send me an article on this or any other build, I would be delighted to publish it in the Journal. Don't forget not all our members use the forum or the internet come to that.
Steve Vodrey
Postby Steve Vodrey » April 2nd, 2016, 4:07 pm
Thanks for that Dave.
The journal featured a build thread for the same SLEC Wellington fairly recently done by Phil Robertshaw.
After letting the paint harden up a bit it was time to pull off all the masking.
Comes off a lot quicker than it goes on...
Masking removed.jpg (68.79 KiB) Viewed 40349 times
Karl mander
Postby Karl mander » April 2nd, 2016, 8:30 pm
WOW! Looks the mutts nuts.
Phil Robertshaw
Postby Phil Robertshaw » April 4th, 2016, 11:57 am
Hi Steve,
Nearly there and looking good. Looking forward to flying mine with you this year.
Cheers. Phil :D
paul needham
Postby paul needham » April 4th, 2016, 7:44 pm
looking rather grand Steve.
Steve Vodrey
Postby Steve Vodrey » April 4th, 2016, 10:01 pm
Thanks for the comments. Just in the process of attaching all the moving surfaces and fitting the gear.
Craig Green
Postby Craig Green » April 11th, 2016, 3:39 am
Looks good Steve, have been peeking in on your build. That covering and paint looks awesome.
What gear are you using?
Cheers, Craig.
Users browsing this forum: No registered users and 40 guests
