I cant complete the airframe ready for covering without getting all the control gear ready, so here goes.
I am using AR9000 receivers and Turnigy 31kg high voltage servos. The receivers can take 8.4v (2 cell LiPo) and so can the servos. The reason the servos use HV is that it reduces the current requuired (power = voltage x current, so higher voltage means less curtrent needed for the same power). The result of all this is that I do not need any voltage regulators. Whilst this is good it also means that I cannot use any of the Powerbox type of units because they all incorporate voltage regulation to a lower voltage.
So, here are all the parts I need to connect some how...
- IMG_2735.JPG (48.78 KiB) Viewed 16244 times
In that pile there are:
4 x 2 cell LiPo's
8 x switches
8 x 15amp diodes ( to allow connection of 2 batteries to each receiver)
2 receivers
4 voltage sensors and displays
telemetry sensor for voltage
telemetry sensor for temperature
telemetry transmitter
In an earlier discussion it was suggested that it is not a good idea to put over 10amps through the end of a standard receiver and that it is better to send current to the servos outside the reciever (like in a powerbox). I have therefore decided to build my own 'Powerbox' running at 8.4volts.
Here is my circuit diagram and the start of making it..
- IMG_2736.JPG (40.09 KiB) Viewed 16244 times
The circuit board in the middle is the standard pre-drilled board with copper strips on it. I was going to use this but I searched online and found a program that calculates how wide the copper strip needs to be for the current you are using. This type of board was no good.
In the pic above you can see another type of board on the left. this is just completely covered in copper. I marked this out with tracks wide enough to carry 10amps and then carefully removed the copper where needed - you can see how much wider the tracks are on my home-made board...
- IMG_2737.JPG (43.18 KiB) Viewed 16244 times
You can also in th epic above that as well as cutting the tracks I have also drilled all the holes needed for the layout I am using. This board layout is actually 2 completely seperate circuits (each half of the board), one for each receiver. Each half has 2 battery inputs that feed through diodes (2 each for security) and then the 2 feeds are connected ready to be fed to all the servos. I have put 'jumpper' leads out to each connection on the receivers and connections out for each servo.
After laying out the board I had another idea and so you can now see a second small circuit board to the right...
- IMG_2739.JPG (62.11 KiB) Viewed 16244 times
The reason I added the second board was so that I could seperate all the signal wires from the power side.....each of the white receiver signal wires is connected on this small board to the outgoing servo wires.
More pictures on the next post.
