This is part LE1, because the root wing rib W1 is set at an angle this part will have to be sanded to allow the front part of W1 to fit into LE1.
Nick Reeves 3055 wrote:following this build with interest
Alan Cantwell 1131 wrote:Can I suggest here, the use of white pva glue, cover the structure with the pva, then use magazines to weigh the skin down, the mags will flex, and bend the skin to the wing, I doubt cyno will do the job as well, it will have gone off before you apply the skin, the pva will penetrate the wood, and give a much stronger bond,
