kill switch
richard welch
kill switch
Postby richard welch » December 26th, 2021, 9:43 am
Hi, I am looking for a zenoah magneto kill switch, i want it to kill the engine is the battery is disconnected, recently my firewall came loose and disconnected the throttle linkage and the kill switch wire going to a servo/micro switch inside the fuselarge, this left the engine on full bore and the kill switch disconnected, anybody have any idears of a kill switch type which will kill the engine when no power is supplied from the battery, most are controlled from the radio and this would not work.
Re: kill switch
Postby Cary Bailey » December 26th, 2021, 11:38 am
Richard, a quick suggestion would be to replace the magneto ignition with a digital ignition such as a RcXel unit and fit with an electronic kill switch. Unfortunately an expense but will sort your issue.
Re: kill switch
Postby John Greenfield » December 27th, 2021, 9:22 am
Fit one of Dave Hayfields failsafe switches. Works with any magneto motor and as an added bonus it will kill the motor if there is a total power loss in the model. He sells direct but you can also find them in his ebay shop.
Users browsing this forum: No registered users and 70 guests
