servo plugs and wiring
Kevin Wesley
Postby Kevin Wesley » January 10th, 2010, 8:46 pm
Hi, Just want to pick a few brains. I'm currently building a 1/3rd scale Balsa USA Super Stearman. I intend to buy heavy duty switches and servo wire from SM Services but am stuck on the type of plugs i should use bearing in mind that i'll be plugging and un-plugging them each time i assemble/dis-assemble the upper and lower wings and tailplane ( i have four ailerons and removeable stab/fin ) do you still use the standard Futaba plugs or is there a better option on the market something that locks maybe ?
Cheers Kev
Steve Morris
Re: servo plugs and wiring
Postby Steve Morris » January 11th, 2010, 9:22 am
Kev, I like the Ashlocks from Ashtek, they are available upto 12 way, so you can double up on power connections if required and also put more than one servo on a connector thus cutting down on the number of plugs. They also as the name suggests lock which makes for great peace of mind.
If you go this route I would also suggest you get the crimping tool from Ash as well, and he also does great twisted HD silicon cable.
His site is here http://ashtekelectronics.com/shop/index.php
On the bottom left of his site you will see a tutorial section, all the info on crimping your own leads is there.
A satisfied customer
Kevin Wesley
Postby Kevin Wesley » January 13th, 2010, 10:51 am
Hi Steve,
Thanks for the advice, After receiving your response i looked at the Ashtec site and the tutorial they seem really good quality. I was a little bit concerned about crimping my own plugs i remember Als Hobbies selling plugs and crimping sets a few years back and after seeing some of my friends attempts thinking that it could be a recipe for disaster, but its nice when you hear from someone who has used the product and who can vouch for it
Thanks again Kev
Postby Phil Clark » January 14th, 2010, 11:20 pm
Another vite for Ashlok connectors & their HD silicone coated wire....excellent product, been usng them for 4-5 years without a single issue.
I also purchased a crimp tool and had trouble with it.....since bought a replacement from RS (pricey) but it's superb.
Kevin Wesley
Postby Kevin Wesley » January 16th, 2010, 8:37 pm
Thank you all for your advice
Regards Kev
Simon Willey
Postby Simon Willey » January 16th, 2010, 8:46 pm
Phil Clark wrote:Another vite for Ashlok connectors & their HD silicone coated wire....excellent product, been usng them for 4-5 years without a single issue.
Have you a part No for the RS one . I was looking in the catalogues but could not find one.
Simon
The Dawn Patrol
LMA No 3109
Postby Phil Clark » January 19th, 2010, 7:43 pm
RS # 481 - 516
It's intended for use with the old 'D Type' computer connectors but works on regular Ashtek and Futaba/JR pins equally as well. (Just make sure you sit down before looking at the price :shock: )
Simon Willey
Postby Simon Willey » January 19th, 2010, 8:20 pm
Thanks Phil
Will get a set ordered. As you said not cheap but worth it for a better crimp
Thanks Simon
The Dawn Patrol
LMA No 3109
Users browsing this forum: No registered users and 81 guests
