Kalt 22cc advice
Frank Skilbeck
Kalt 22cc advice
Postby Frank Skilbeck » September 6th, 2023, 7:00 pm
I've acquired a model with an old Kalt 22cc (basically a Zenoah 23cc magneto) petrol engine, initially it wouldn't run so I replaced the rubber bits in the Walbro carb (WT705), it runs now but I can't slow it down. As I reduce the throttle the engine revs drop to just under 3,000 rpm, but then reducing the throttle further sees the rpm increase. At full throttle it's turning a 16 x 8 at just under 7,000 rpm.
Any suggestions?
Frank Skilbeck
Re: Kalt 22cc advice
Postby Frank Skilbeck » September 13th, 2023, 8:06 pm
Turned out to be a gasket problem not sealing the carb to the engine, allowing air in, made up some new gaskets and it's running well now with a steady low tickover, now if I could just find a way to cheaply quieten it down it would be a good engine.
