2x Powerbox iGyro 3e 3-Axis Gyro 3600 and PowerBox BlueCom Wireless Setup Adapter NEW
RichardHughes
Postby RichardHughes » October 5th, 2025, 12:15 pm
2x Powerbox iGyro 3e 3-Axis Gyro 3600 (rrp £225 each)
PowerBox BlueCom Adapter Wireless Updates and Setup of PowerBox and Smoke EL Products 9021 (rrp £45)
New & boxed. All 3 items =rrp £495 – Bargain all for just £280.
The iGyro 3e is the little brother of the iGyro SRS, and offers an excellent performance. The control characteristics are identical to those of the iGyro SRS, and naturally the unit’s quality also reflects the very highest PowerBox standard!
The iGyro 3e operates with normal PWM signals at the input and output, making it a straightforward task to install and set up the gyro in existing models. The iGyro 3e is simply looped in between the receiver and servos, and its gain can be adjusted in flight if one auxiliary channel is assigned to it. The net result is that it takes just a few minutes to install and set up the iGyro 3e.
The gain adjuster is divided into two ranges, enabling the pilot to pre-define different flight modes with the transmitter. As standard the iGyro 3e can be operated in Heading or Damping mode. Heading mode has been specially developed for fixed-wing model aircraft, and provides natural handling in the air. As you would expect, Heading mode can be left active for take-off and landing! It is supremely easy to adjust the ranges of the gain adjuster using a laptop,PC, or new with Mobilphone, as the Heading option and the strength of the gyro effect are fully variable, separately for each output.
Naturally the unit also features an integral delta and V-tail mixer, and any orientation in the model is possible.
Features:
• Extremely accurate triple-axis MEMS sensor
• Special regulatory algorithm designed for fixed-wing model aircraft
• Three axes distributed to five servos, each adjustable independently
• Input and output with PWM Signals
• Input for in-flight gain adjustment
• Heading or Normal mode can be selected in flight
• Integral delta mixer
• Installed orientation can be selected
• 16-bit processor for fast, high-resolution signal processing
• Updateable with PowerBox Systems USB Interface connectors
• Robust aluminium case
Technical Data:
Operating Voltage: 4.0V - 9.0V
Current Drain Power-on State: 40mA
Maximum Load Current: 20A
Signal Input: PWM
Servo Sockets: 5
Servo Signal Resolution: 0,5µs
Gyro Regulation: Heading- and Normalmode
Gyro Sensor Type: MEMS
Number Of Sensor Axes: 3
Dimentions: 43 x 30 x 15 mm
Weight: 36g, inc. 6 Patchleads
Temprature Range: -30°C to +75°C
PowerBox BlueCom Adapter Wireless Updates and Setup of PowerBox and Smoke EL Products 9021 (rrp£45)
BlueCom Wireless Adapter for Updates & Setup of PowerBox / Smoke EL 9021
In conjunction with the Mobile Terminal, the BlueCom™ Adapter provides a means of wirelessly setting up PowerBox products, or updating the software.
In this way you can carry out all adjustments to devices such as the Powerbox Pioneer and iGyro 3xtra and many other products, conveniently and without any wired connection in the model.
Features
• Wireless Bluetooth connection between a PowerBox device and the Mobile Terminal
• Wireless updates and set-up procedures
