Spitfire Power Question
Jason Griffiths
Postby Jason Griffiths » April 22nd, 2010, 11:13 pm
Hello Everyone,
Right at the moment im building a Pica 1:5th sports scale Spitfire,iv been on the build board for 2 years now but it's getting there.
The question is what engine should i use,i would like to keep the standard wood engine bearers which come with the kit and now iv glued them all in don't want to start cutting it about if possible.
I know someone selling a Super Tigre 45 would this be too much for it,and also iv found a new Super Tigre 3000 would this be ok as im not sure what or what to go for.
Any info/help welcome 8-)
Thanks 8-)
andywynn
Re: Spitfire Power Question
Postby andywynn » April 23rd, 2010, 8:16 am
Hi Jason,
Whats the expected all up weight going to be now youve more or less finished it?
There are issues with Super Tiger motors inverted, ( i know i flew a Mk V with a tigre 45 in for years) they don't like starting on a flick upside down, so you either get a starter that can spin it over so you can start it on its wheels or you start the plane upside down and turn it over once its running :shock:
If you want to keep it in the bearers then you are very limited to probably the larger glo engines OS 200 saito 180 etc, depending on the weight. Personally i would cut the bearers off, tiger 25/30/3250 all come with a bell housing as well as a option to mount on bearers, 45 comes with a metal mount as its rear induction. If you do that then you can choose the best motor for the plane, by this i mean if you need nose weight (most do) then you can put a bigger engine in.
Hope that helps :D
Andy
Jason Griffiths
Postby Jason Griffiths » April 23rd, 2010, 9:46 am
Hello Andy,
Iv not weighed it yet as still need to sand the fus into shape,then ill get it on the scales in the next few days for a rough weight as there is no servo's ft=itted yet eaither :roll:
I was thinking of a SC 180 or a Saito 180 as you sad think i best get sanding then weighing and get back on here ;)
Thanks 8-)
Simon Fowler
Postby Simon Fowler » April 23rd, 2010, 10:25 am
:) Hi, Jason.
Sorry for being a PEST on the forum, but, I squeezed a Moki 210 into mine. 8-)
The Guys at the car exhaust repair centre made a homemade outlet for it...
Sorry, dont know how to download pics.,
Chow, Si.
Jason Griffiths
Postby Jason Griffiths » April 23rd, 2010, 10:47 am
Hello Si :D
If you could get a pictures of it that would be great or if you could email me some 8-)
Does it fly well ?
Thanks 8-)
Simon Fowler
Postby Simon Fowler » April 24th, 2010, 6:32 am
:) Howzit? Jason.
Send me your E-mail thingy, and I`ll send some pics. I am still a bit too STUPID for this "Satanic" computer goody. :oops:
Yes, it flies well, though a bit on the heavy side. Need to keep the speed up and takes some getting used to.
We fly out in the "Bundus" on a dirt strip, so a lot of rudder and elevator juggling, to prevent a nose-over in
the dirt. I initually had soft tyres on it, but the "Bloody" thorns kept puncturing them, so I put solids on..
You have nice grass fields there, so not a problem. :D :D Landings a bit faster than my Pitts planes, but
is awesome in the air. Also, our altitude is a lot higher.
Chow, Si. 8-)
Jason Griffiths
Postby Jason Griffiths » April 24th, 2010, 7:31 am
Morning Si,
Iv just sent you a PM with my email address in 8-) im looking forward to seeing your pictures.
Thanks 8-)
