Building A Mosquito?
Alex McCormick
Postby Alex McCormick » July 19th, 2010, 9:57 am
Hello Folks,
Is there anyone, or does anyone know of some one building a Mosquito? I am looking for a decent kit if there is one available, having burnt the 1/4 scale Spitfire on the woodburner what a pile of s**t that was for quality. :evil:
If someone could point me in the right direction I would be most grateful. :)
Thank you in advance.
Al........
Re: Building A Mosquito?
Postby Phil Clark » July 19th, 2010, 11:40 am
Mick Reeves - Kit around 100" span
Brian Taylor - plan (in 2 sizes - 60something & 80something IIRC)
Richard Rawle - plan (approx 120")
Don Smith - plan (approx 120")
Alex McCormick
Postby Alex McCormick » July 19th, 2010, 4:00 pm
Thanks for that Phil, I have looked into a couple of the mentioned, bit dubious about Mick Reeves as I had 1/4 scale kit wooden Spitfire and it ended up in the woodburner due to not been impressed by the quality of the drawings and the kit. I would like to also point out that I am not the only person to comment on the quality of this particular scale model. :shock:
Anyway thanks for that Phil. :)
wayne owen
Postby wayne owen » July 19th, 2010, 7:21 pm
hi alex
FC SCALE PARTS the old fiberclassic site are doing a cracker mate 150" span :shock: check it out im going too try and get my hands on one she needs 2 60cc zenohas, hope that helps ,
regards and happy landings :D
Postby stewart clifford » July 21st, 2010, 3:45 pm
I want one too, let me know if you find a good one.
Stewart
Pat Marsden
Postby Pat Marsden » July 25th, 2010, 10:10 am
I do know of someone building a 1/4 scale Mozzy from his own design, ribs/formers etc are all cad designed and cut out and its designed for electric, still in the build stage but hoping to have it finished by Xmas. If it helps I can ask him and the wood cutter of any plans to kit it. I suspect the plan could be modified fo petrol power if required. All up weight of the electric version anticipated to be around 30lb. There is also the Richard Rawle 1/4 scale one available, Richard is often on here and has a couple of airframes in the for sale section up for grabs.
Postby Phil Clark » July 27th, 2010, 10:04 pm
Richard Mossie is 1/5 scale Pat....................130" span IIRC
But a 1/4 scale one at 30lb.................. :shock:....160"+....what does he build from, Helium!!!
Pat Marsden
Postby Pat Marsden » July 28th, 2010, 6:04 pm
Hi Phil
The wood down here is much lighter than up north obviously :lol: , quarter scale is correct, 13ft 4in in old money so should make for an imposing aircraft, cant wait to get my hands on it. The builder ( no names, no pack drill) has built several large electric aircraft and his design and build technique is well proven so if he says hes hoping to get it around the 30lb mark I wouldnt want to put money on him not doing it :D
Another cracking build thread on the Marauder by the way, shame its going abroad on completion as I may have actually attended a show to see that one, beautiful aircraft not commonly modelled.
Pat
Postby Phil Clark » July 29th, 2010, 8:53 am
Hi PaT
Just my opinon here, but why is he aiming to build it so light?....................at 1/4 scale, thats just over 28 sq ft of wing area.........so will give a loading of a little over 1lb sq ft!!!!...................thats glider territory rather than heavy metal (or wood in this case :lol: ) I wouldn't fancy flying it on anything but a flat calm day. I've seen the smaller 1/5 Rawle ones at almost double that weight and they fly fine........
Richard Rawle
Postby Richard Rawle » July 29th, 2010, 7:40 pm
Hi all
My 1/5 scale model is 48 Ibs and when I get around to finishing me 1/4 one ( hope this year) will be around 80Ibs and thats working hard to keep the weight down. most of the weight is in the hard ware. The mossi is a builders plane as well as a pilots plane. It looks easyer than it is round fuz and there is a step in the top surface of the wing witch throws people, its hiden in the top nacel fairing.
I hope this is of help
Richard
Mark Partington 2989
Postby Mark Partington 2989 » July 29th, 2010, 9:48 pm
Richard,
Will the plans and glass work be available for the 1/4 Mossie?
Mark
Mark.
Tonka Toys, Big Boys Toys
Richard Rawle
Postby Richard Rawle » July 30th, 2010, 12:03 pm
Mark
Is there enough intreast out there for it. Its a builders model. Be intreasted on the feed back.
Richard
Postby Mark Partington 2989 » July 30th, 2010, 9:35 pm
Richard,
I'm certainly interested :D
What might gain more interest from others, would be if you worked with one of the kit-cutters to allow a builder to buy a semi-kit of the cut parts, (wing ribs, fuselage frame, etc.), I believe there's a market, for a decent sized Mossie, possibly from the USA.
What engines are you planning on using? A pair of 62s??
Mark.
Mark.
Pat Marsden
Postby Pat Marsden » July 31st, 2010, 5:33 am
The builder just likes to build light aircraft I suppose and being electric I believe there are only a limited amount of motors out there that would power a heavy version without serious amounts of money being involved. He has built several large electric aircraft around the 30 to 40lb weight and I am sure the Mosquito will fly right. I will see if I can get him to put more details on here eventually but I suspect he wants to build it first.
It looks like I was right but slightly ahead of the game though, Richard is currently building a 1/4 scale Mozzy.
Pat
Postby Phil Clark » July 31st, 2010, 10:55 am
Agree with you regarding the 'cost' of electric systems.......there are hugely powerful systems out there, but at a price. The Hacker H-200 + 14s 13,500Mah LiPo system we fitted in Al's 1/4 scale Spit last year was bonkers money......but the power it developed was staggering (scared me more than any petrol engine ever has).....so the old idea of electrics must be light has literaly been blown out the window.
A pair of these systems in a 1/4 Mossie would be stunning (But you'd need to remortage the house to buy them and use Sizewell to charge it!!!!)
http://www.youtube.com/watch?v=wrsGbepnVPc
Richard Rawle
Postby Richard Rawle » August 1st, 2010, 12:45 pm
Mark
It was inteaded to have 2 x 62 mount straight in but have gone for 2 geared 62 with scale props. Had to do some work on the gearing for them to line up with the engines to run true. The idea is to get it flying before putting the detail on and find how it handles.
Richard
