JC 51 Engine
John Evans
JC 51 Engine
Postby John Evans » September 25th, 2010, 3:17 pm
Information required please for this model engine.
1)Needle settings for the high and low jets.
2)Any problems anyone as incurred with this type of engine.
Friend having problem with getting his to run properly, fitted in a quarter scale chipmunk.
John Evans
Dave Tregaskes
Re: JC 51 Engine
Postby Dave Tregaskes » September 25th, 2010, 8:38 pm
Hi John,
I have a JC area 51, absolutely brilliant engine, but I had trouble initially setting up the carburation.
It will not run at full throttle unless the high needle is at least 2 and 3/4 turns open - that is after running in.
present settings are - low needle 7/8 turn open and high needle 2 and 3/4 turns open.
If the engine dies when you try to open the throttle to full - richen to at least 3 or 4 turns on the high needle and try again.
Best of luck - Dave Tregaskes - LMA 2474
John Evans
Re: JC 51 Engine
Postby John Evans » September 26th, 2010, 9:19 am
Hi Dave
Your information is the same as Al,s who has the engine. It appears you and many others are happy will this type of engine, but now and again there is a faulty carburetta out there. Since the posting was made ,Al has made some alteration to the carb and is now getting far better results.
Thank you for time and information
John evans
