My Jet Indulgence
Vince Raia
My Jet Indulgence
Postby Vince Raia » February 20th, 2011, 2:08 pm
Okay, so now I've Cajoled Dave into adding this new subject to the forum :lol: (thanks) I thought I'd better start putting my pen to paper and contribute a posting.
I got the bug for jet turbines after having a fly of Ali Mashinchy's Boomerang XL at my Hastings Club, when they arranged for the club members to have a go at flying jets.
I got the chance to own my first jet, a boomer intro from Tony Hooper, which I stripped, rebuilt and recovered, and reinstalled the running gear plus rewired it, as it had seen a lot of flying with Tony and was looking rather tired.
The model unfortunately only lasted four flights :cry: and went in on the fifth due to an early Spektrum 2.4 plug-in module, where the aerial wire was connected via a brass nut, which came loose and caused a lockout. (Evidently it was muted that you needed to Locktite the nut on :cry: which I discovered too late)
So I purchased another S/H airframe from a friend for £250, which also needed revamping and recovering.
My Wren turbine had to be sent back to Wren as the bearings were grumbling, plus I needed a new Fod Guard, EGT sensor probe, ECU and mounting bracket, which cost me just under £500 :cry:
The Intro is now recovered with modifications to the air intakes and a new floor. (Due to the original being fuel soaked) The model came with retracting piano wire legs, this has now been updated to Jet1A trailing link oleos, and Behotec C50 retracts units.
At the moment I am in the process of installing the components on the internal systems tray, and I have just purchased a bigger air tank for the retracts and brakes, and a Powerbox switch with incorporated battery backer, the receiver is a Spektrum 2.4 5channel unit, which will be flown using a JR DSX9 transmitter.
Whilst the Intro was out of service, and before I started its rebuild, I purchased a Boomerang XL, which has a low hours Simjet 3000 turbine. This model was also stripped out and has had a reinstall and update of all the radio equipment, new systems board, and new air system.
The model has now been fitted with a Powerbox Evolution, JR 2.4 9channel receiver, and two JR Matchbox’s, two Jetronic electronic valves operating the Jet1A retracts, with trailing link oleos and brakes.
When I bought the model it was fitted with Hitec 925 servos, these have now been replace with JR 8411’s, the model also had a Tamjet smoke system, and an Eagle Tree telemetry system on 35Mhz, both of which have been removed. The model also came with an old glow fuel bottle for a tank, that was also discarded and a proper Sullivan XL 4ltr tank installed. The model is now awaiting some decent weather to test fly.
I am also the proud owner of four Avonds F15’s, this is a jet I have always liked and wanted a model of, but why four? You may ask, well it was quite unintentional really; I went up to Yorkshire to buy a turbine version, which was in a grey military scheme, he also had a lovely (non scale) triple coloured model that was fitted out with an OS91 Ducted Fan unit, as both models were very reasonably priced, I bought the two. The multi-coloured version has now been stripped of all the ducted fan equipment but I was short of a S/S bifurcated pipe and other accessories associated with the turbine version.
Another friend had one and had destroyed the nose on take-off; I offered to buy it from him for the parts. Whilst he was making his mind up what to do, another one came up on the BMFA cheap not too far away, so I immediately phoned the guy and arranged to go see it, I did so and bought the model, well the airframe is in reasonable nick, although the interior has been stripped out as he had just repainted it in an off-white colour. (I got the pipe, the retracts & tanks separate)
Meanwhile, my friend decided to take a small amount for his damaged model, which included the pipe, retracts, and the tanks, which has now given me an assortment of parts to build a couple of models, of course I won’t be keeping them all, but you can’t beat a few spares :lol:
The damaged one I will eventually make a new F/Glass nose for and probably move it on. I intend to refurbish and do up the white version for my first training F15. I will add some colour to it, will do it in the Red, White & Blue Anniversary scheme, as it’s a scheme I like, my XL is also done in the same scheme. The Military version needs repainting as its flaking, this will be re-done in a military scheme as it has a lot of the scale features like undercarriage doors and grills etc. I may even get a rocket set to complete the scale appearance, but that is all in the future ;)
I’ll add a couple of photos of my models later.
Vince.
Ken Bones
Re: My Jet Indulgence
Postby Ken Bones » February 20th, 2011, 4:26 pm
Vince, you been busy!
Bonzey
Vince Raia
Postby Vince Raia » February 21st, 2011, 9:11 am
Hi Ken, not busy enough really :lol: mind you, with all this crapp weather I do more work on my hangar queens than I do flying them:lol:
Postby Andy Boylett » February 21st, 2011, 1:56 pm
Hi Vince, I'm feeling jealous of that lot :mrgreen: fantastic, well done. Lets see some pictures.
Vince Raia
Postby Vince Raia » February 22nd, 2011, 10:16 am
Hi Andy, well I run my hobby on a "Shoestring" really :) am selling (and have sold) most of my prop planes to help fund my jet craving :D so a few of my F15's will get sorted as the money becomes available, and unfortunately there are one or two other model that I fancy, but that's in the future :mrgreen: (maybe)
Anyway, here are a couple of photos of my stored airframes and my XL, and I'll add one of my original refurbished Intro at Bickley Jets 09 before it's demise.
Vince
PS I'll post more Info as and when I start my other projects
Vince Raia
Postby Vince Raia » July 16th, 2011, 1:02 pm
While I was on this Jet Forum I'd thought I might update my initial posting.
Boomerang XL:
This jet is awaiting a test flight weather and time permitting. It has now been fitted with a Jetcat 120se turbine, that I have also converted over to Kero Start, so really looking forward to getting it airborne.
Boomerang Intro:
I have now finished refurbishing another airframe for the Intro, and modified the back airframe to take a bigger turbine that I had in stock, a Simjet 19lb turbine in place of the Wren 54. I am just in the process of making a new systems board/tray to accept the different running components of the Simjet, which will also soon be ready to test fly.
Jet Legend L39 Abatross (1/5th scale)
This will be the next jet to be fitted out with turbine & radio. It will be fitted with a Simjet 3000 (30lb) turbine. The aircraft is in the Breitling colours, a cracking looking aircraft that I can hardly wit to get ready for flight.
Avonds F15's:
At the moment these airframes are on the back burner, although I have four of them :shock: two will be sold on, as i want to do one as a nice scale aircraft, and another for general flying, but that's if I live long enough :D
Cheers, Vince.
Return to “Jets”
