Pink or blue foam
Mike altham
Pink or blue foam
Postby Mike altham » February 21st, 2011, 3:02 pm
Just wondering where I can get hold of any of this?
Mike.
Re: Pink or blue foam
Postby DAVE JOHNSON » February 21st, 2011, 5:38 pm
Mike---what sort of amount do you need?? i have a few blocks knocking about if its only small pieces you need??
Robert Mahoney
Postby Robert Mahoney » February 21st, 2011, 10:36 pm
Hi Mike, you can get it from Sheffield Insulations, web site is http://www.sheffins.co.uk/
best of luck
Robert Mahoney
Postby Andy Boylett » February 21st, 2011, 11:14 pm
Mike,
You need to be careful about the foam because there are different types. The best for model making are the closed cell foams with a very small cell size. I got mine form this guy selling on Ebay. He is buying larger sheets and cutting them up (they are sold for house insulation but you have to buy £150 worth at a time). Here is a link...
http://shop.ebay.co.uk/02robbo/m.html?_nkw=foam&_sacat=0&_odkw=&_osacat=0&_trksid=p3911.c0.m270.l1313
This foam is superb and cuts/sands to a really nice finish.
Cheers, Andy
Mike altham
Postby Mike altham » February 22nd, 2011, 9:19 am
Hi Guys,
Cheers for the help.
I think I have found some at travis perkins about 1.5 miles away from where I live.
Mike.
Postby Phil Clark » February 22nd, 2011, 9:29 am
Careful with the blue foam you can buy cheap from builders merchants.......this is often a very 'rubbery' foam that when sanded drags big lumps out (OK for hot wire cutting wings though)
If you want a nice closed cell sandable foam for making plugs etc....'IB Styrofoam' from Sheffield Insulation. It works a bit like 'Oasis' used for flower arranging, but is MUCH lighter.
Last edited by Phil Clark on February 22nd, 2011, 8:51 pm, edited 1 time in total.
Postby Mike Booth » February 22nd, 2011, 6:26 pm
In agreement with Phil, blue foam will tear quite easily, when sanded.
Also on health and safety, both foams vent an inert gas when sanded, so good ventilation or better still some form of extraction system is desirable.
Mike Lee
Postby Mike Lee » February 22nd, 2011, 7:37 pm
I got some from panelsystems.co.uk. You get it mail order in different sizes. None too cheap though. I used it for making moulds.
Mike.
Mike altham
Postby Mike altham » March 2nd, 2011, 7:47 am
Found some really light high density pink foam at B and Q made by knauf.
only around 1.5" thick but it will do the trick.
Mike.
Mike altham
Postby Mike altham » May 2nd, 2012, 9:24 pm
Back again on this issue.
B n q have thoughtfully stopped selling the pink foam. Any one know of where I can get pink foam from?
Locally around Manchester?
Mike
paul hughes
Postby paul hughes » May 3rd, 2012, 7:53 am
How much do you need Mike and what thickness? I have some largish off cuts. I live near Bury.
Postby Phil Clark » May 3rd, 2012, 8:29 am
Find your local branch of 'Sheffield Insulation'..............or any large industrial insulation firm for that matter, they should have various blue, pink & yellow foams.
Mike altham
Postby Mike altham » May 3rd, 2012, 9:43 am
Cheers for the info
I only need it 1.5" thick and three pieces about 10" x 9"
There is a sheffins in Trafford park. Will give them a ring.
Mike
paul hughes
Postby paul hughes » May 3rd, 2012, 9:58 am
I can cut you pieces that size (out of a 4" thick sheet) at work if you want then.
Mike altham
Postby Mike altham » May 3rd, 2012, 10:59 am
Hi Paul
If it's 4" I would only need 2 pieces. As then I could cut them in half and get 4 pieces if you know what I mean. How much would you want for them?
Mike
paul hughes
Postby paul hughes » May 3rd, 2012, 2:42 pm
Hi Mike, I will sort them out for you tonight. as for cost, how about a the price of pint sometime. You will need to collect.
Mike altham
Postby Mike altham » May 3rd, 2012, 3:34 pm
Hi Paul
Ok thank you. Sound like a good deal.
Could you pm me your address and phone number and best time to pop round?
I'm only in Oldham
Thanks again
Mike
