Intake tubes?
Mike altham
Intake tubes?
Postby Mike altham » March 17th, 2011, 11:34 am
Just wondering what you guys make intake tubes from?
I have thought get a metre long length of drain pipe, the correct size, then smear with release agent, put a layer of glass fibre on it, then place strips of 1/16 balsa down the length of it and then cover that with glass fibre, then slide the pipe out to leave you with a light strong tube.
I think it would be strong enough so it would not collapse under the vacume of the engine air intake.
Mike.
Re: Intake tubes?
Postby Phil Clark » March 18th, 2011, 1:32 pm
To save you the hassle of laying up glass, why not use the pipe as a mould and wrap 'Proskin' (thin glass fibre sheet sold by Mick Reeves) around the outside and stiffen with carbon tape/tows every few inches? Just make sure you key the outer surface VERY well before applying resin & carbon as not mush like sticking to the very smooth surface of the Proskin.
Mike altham
Re: Intake tubes?
Postby Mike altham » March 23rd, 2011, 7:26 am
Hi Phil,
Ok cheers,
Will give it a go.
The intake tubes are 7" wide by 6" high
Mike.
Mike altham
Re: Intake tubes?
Postby Mike altham » October 27th, 2011, 1:33 pm
Found a company in Bradford that does the Proskin or G10 FR4
Called presspahn.
For 0.2 or 0.4mm thick it is £29.24 + VAT and shipping and is 1220mm x 910mm
Mike.
Users browsing this forum: No registered users and 100 guests
