Multiplex Royal Transmitter
barrie burton
Postby barrie burton » April 4th, 2011, 8:53 am
Does anyone know if the FRSKY 2.4 ghz system will work when fitted into the MPX Royal transmitter.The transmitter has been upgraded to version 3.3 software.
Dave Hayfield
Re: Multiplex Royal Transmitter
Postby Dave Hayfield » July 17th, 2012, 1:30 pm
Hi Barrie, just picked up your query about FRsky 2.4 conversion. I'm in the process of doing the same to my very old Multiplex Expert 'softmodule' gear because I would still like to use it with it's quaint but efficient programming systems, after all it did cost nearly 600quid 20 years ago!! and never let me down. If I come across any probs I will let you know but so far so good.
Thanet Model Flying Club
LMA 520
barrie burton
Postby barrie burton » July 18th, 2012, 4:41 pm
Thanks Dave.I have been a MPX fan since day one,well almost.Problem is now sorted,my Royal transmitter had to go back one step,software wise,then i could use the Frsky module.My 3 MPX transmitters are all now conveted to 2.4.My 3030 uses Jeti Duplex and my Cockpit and Royal both use Frsky.No glitches,other than self induced,with any of them.
Bi Barrie B
Dave Hayfield
Postby Dave Hayfield » July 19th, 2012, 5:15 pm
Barrie, glad to hear your FRsky stuff works ok. I have done a few test flights with my conversion using a lightweight foam electric model (to reduce collatteral damage) and seems ok . Looking at the Frsky spec. the output wattage is 60mw compared to the 100 mw of most of the 2.4 on the market. My son,Greg, does a lot of glider comps and he says that flyers are using Frsky stuff at extreme range. I'm not sure about a big power model at extreme range with my conversion at the moment though.
Last edited by Dave Hayfield on September 11th, 2012, 12:37 pm, edited 2 times in total.
LMA 520
Dave Hayfield
Postby Dave Hayfield » August 22nd, 2012, 10:01 am
Hi Barry, just thought I would let you know that I installed the FrSky gear in my trusty old 62cc Megawot after doing extensive checks in the foam test bed model. Pleased to report results are absolutely fine. I wonder if the old MPX Royal will last another 20 years??
LMA 520
Return to “Radio Equipment”
Users browsing this forum: No registered users and 44 guests
