Measuring wing/tail incidence?????
Mike altham
Postby Mike altham » August 18th, 2011, 9:48 pm
Hi guys
I have a tiny problem. On the nimrod I have the incidence to be set at 0 0. But the centre section is around 1600 mm chord. How do I do it as they don't make metres that big do they?
Mike
John Townsend 389
Re: Measuring wing/tail incidence?????
Postby John Townsend 389 » August 19th, 2011, 1:08 pm
Mike, simply just temp. glue a balsa strip with top edge at the centres of the leading and trailing edges, place equal height blocks on the strips and lay a straight edge on the blocks. Place your meter on the straight edge and bingo you can measure the incidence or determine by calculation.
Mike altham
Postby Mike altham » August 21st, 2011, 2:02 pm
Hi john
Thanks for that
Stupid question but would you measure the incidence from the outer of the centre section to set the tail or would you take it from the outer wing panels. But these have 2 degrees of washout in them?
Mike
John Townsend 389
Postby John Townsend 389 » August 22nd, 2011, 12:29 pm
Mike,
Measure at the wing root.
Mike altham
Postby Mike altham » August 22nd, 2011, 3:57 pm
Hi john
Ok cheers
Mike
