ziroli c47 build
paul smith
ziroli c47 build
Postby paul smith » September 24th, 2011, 8:09 am
Hello all
Have just started a ziroli c47 pics of the build progress to followp :P
paul smith
Re: ziroli c47 build
Postby paul smith » September 24th, 2011, 4:34 pm
stabilizer and elevators complete before covering
found out that using thin ca causes the wood to become brittle,
so i will be using woodglue and A B only for the important joints
stab edges and elevators.jpg (41.9 KiB) Viewed 26269 times
paul smith
Postby paul smith » September 24th, 2011, 4:35 pm
next stage is to start the fin and rudder sections
Postby DAVE JOHNSON » September 24th, 2011, 6:01 pm
Paul--watching with interest--the Dak is one of my favourite aircraft---i do agree with you about the cyno,i decided to resort to the white glue as well for my build--DAVE
chris willis
Postby chris willis » September 24th, 2011, 8:46 pm
Hooked in Paul, I use aliphatic, easy to sand.
David Jones
Postby David Jones » September 25th, 2011, 10:38 am
Keep it coming, this will be next on my building board once I've finished a 1/5 scale Vampire. Are using the fibre glass nose section thats available, or are you going to carve and sand it from soft block? Also, what engines due you intend to install?
Dave Jones.
paul smith
Postby paul smith » September 25th, 2011, 11:13 am
Hi all
Thanks Guys
The last ziroli DC3 i built i used thin CA to assemble it, about a month later it decided to fall apart and it ended up in the bin (a very expensive mistake). I will definatly use lots of wood glue this time, and use thin CA to just to tack wood parts for those awkward holds before reinforcing them with wood glue.
luckily I have kept the fiberglass nose, cowls, robart retracts, from the build that went wrong, so will be using those
I think 2 Zenoah G38s with tri blades are the best choice for reliability in the air. Any help would be apreciated
will post some more pics as build progresses
P :0)
paul smith
Postby paul smith » September 27th, 2011, 4:29 pm
rudder assembly
rudder build.jpg (47.25 KiB) Viewed 26071 times
rudder build 2.jpg (42.66 KiB) Viewed 26071 times
paul smith
Postby paul smith » September 28th, 2011, 9:33 am
rudder assembly
Last edited by paul smith on October 9th, 2011, 11:31 am, edited 3 times in total.
Postby Mike Booth » September 28th, 2011, 7:19 pm
Paul sorry , the project looks great but is that rudder driver really up to the job on the engineering front.
Surely that soft solder and wire will let go of the rod at some point.
The elevators will have 3mm plus rods and big balljoint connectors.?
paul smith
Postby paul smith » October 9th, 2011, 11:20 am
rudder assembly
rudder fin.jpg (52.57 KiB) Viewed 25883 times
paul smith
Postby paul smith » October 9th, 2011, 11:22 am
fin assembly
fin 2.jpg (46.32 KiB) Viewed 25884 times
paul smith
Postby paul smith » October 9th, 2011, 11:23 am
fuz crutch assrmbly
fuz crutch 1.jpg (42.17 KiB) Viewed 25888 times
paul smith
Postby paul smith » October 9th, 2011, 11:25 am
fuz crutch and formers
crutch and formers3.jpg (41.55 KiB) Viewed 25888 times
paul smith
Postby paul smith » October 9th, 2011, 11:33 am
Thanks mike
yes!! using soft solder for the joint is abit rough
and unreliable.
have re built the joint with silver solder
!alot stonger!
Thanks for the info
paul smith
Postby paul smith » October 9th, 2011, 11:36 am
fuz formers
crutch and formers5.jpg (43.45 KiB) Viewed 25890 times
stuart cotgrove
Postby stuart cotgrove » October 9th, 2011, 11:47 am
Lovely, subscribed and booked into this one... :D
paul smith
Postby paul smith » October 12th, 2011, 5:08 pm
stab holder
stab holder1.jpg (44.18 KiB) Viewed 25786 times
paul smith
Postby paul smith » October 12th, 2011, 5:09 pm
test fitting the stab and rudder
stab rudder and fin test fit.jpg (46.58 KiB) Viewed 25790 times
paul smith
Postby paul smith » October 16th, 2011, 7:31 pm
tail wheel assy
Users browsing this forum: No registered users and 34 guests
