Spray painting
Spray painting
Postby Andy Boylett » January 29th, 2012, 12:05 pm
I went to do some spray gloss painting this morning but my paint was clearly too cold !! The paint is now in the house warming up. I wondered if someone knows what the minimum temperature that it is OK to spray at? The shed where I have my half scale Spacewalker has no heating :( .
Cheers, Andy
Re: Spray painting
Postby Bob Thompson1894 » January 29th, 2012, 3:48 pm
Short answer is- DONT! If you cant warm your shed to a pleasant ambient temperature, then wait for a bit of spring!
John Rickett
Re: Spray painting
Postby John Rickett » January 29th, 2012, 7:01 pm
The viscosity of the paint can be reduced with extra thinners, however the problem lies not only with the temperature of the paint but the surface to be sprayed. In this country, if its cold then almost certainly there will be a high humidity and if the dewpoint is reached, a thin layer of moisture will be present on the surface. There is also a risk that handing the piece to be painted will cause moisture from your hands to be deposited and which will not evaporate. If sprayed on, especially if the surface is impervious, the moisture will be trapped and will manifest itself later on by small bubbles appearing.
Even if you spray when the air is close to, but above, the dewpoint (100% relative humidity) the evaporating thinners will lower the temperature a bit more and may just trip you into 100% RH, causing moisture to form on your beautifully painted surface.
If you really must paint in the cold, choose a sunny day and mid-morning time when the temperature is rising - don't try to paint at 3 o'clock in the afternoon unless you can then get the painted piece into the warm to dry...........or as Bob says, wait until Spring.
Re: Spray painting
Postby Andy Boylett » January 30th, 2012, 10:15 pm
Thanks guys, much appreciated. Any idea when spring will start ? :D
I also noticed that if I use my gas heater when it is coldish then after a little while there is a layer of condensate over everything in my model room - obviosly because the heater produces water vapour!!
I also suggested to my wife that maybe I could do spraying in the conservatory. She reminded me of that guy who was in the papers recently when he got a compressed air hose stuck up somewhere!!! :shock:
Cheers, Andy
Re: Spray painting
Postby Bob Thompson1894 » January 31st, 2012, 9:34 am
As I write, its 1' outside, and little bits of snow are drifting down. Spring seems a loooong way away. Now, about this global warming....
