ziroli dc3 servo positions
paul smith
Postby paul smith » February 11th, 2012, 8:55 pm
Hi All
i am aproaching the installation of the servos in this biggy
the 1985 plan says to fit the 2 elevator servos in the middle to front location of the fuz.
the Lma inspector advised that i fit the servos into the stab, but have read on several forums that
this would cause a c of g issue please can any one help as i am totally confused
many thanks
Paul
Re: ziroli dc3 servo positions
Postby DAVE JOHNSON » February 11th, 2012, 9:18 pm
Paul---i would take the advice of your inspector---there is far less chance of any backlash /slop/flutter if you put short linkages direct to the elevators,i have set up and flown several of the Zirolli DC3,you will need a good chunk of lead up front for balance anyway,so a little more to counterbalance the servos wont be a problem---best of luck with the rest of the build---DAVE
Postby Alan Cantwell 1131 » February 11th, 2012, 10:24 pm
think of the weighty push rods you wont be using, short 2 heavy duty arms, 2x 3mm pushrods, 2 ball links, 2 kavan 3mm clevises work for me,
paul smith
Postby paul smith » February 14th, 2012, 2:47 pm
Thanks guys for the advice very helpfull many thanks
P :0)
Postby Mike Booth » February 14th, 2012, 6:34 pm
I'm going to write an artical on this one for the journal.
Users browsing this forum: Bing [Bot] and 39 guests
