Painting grp parts
Chris Lane
Painting grp parts
Postby Chris Lane » February 11th, 2012, 9:17 pm
Hi, I have some splendid wheel spats and a cowl moulded in grp. What is the word on finishing these please. I assume a good scrub with warm soapy water to remove any residual release agent is the starting point?
Chris Lane 2938
John Rickett
Re: Painting grp parts
Postby John Rickett » February 12th, 2012, 8:51 am
Chris,
Use 240 grade, or therebouts, wet and dry paper to abrade the surface and remove the release agent residue. For best results, change the water a couple of times (and change the wet and dry) to completely wash away any silicone. Using a fairly coarse paper will provide a good surface for painting.
Brush or spray a primer and rub down, again with 240 wet and dry. The plain, matt primer will show up any pin holes and blemishes which can be filled with a stopper - P38 works fine with grp.
Apply further coats of primer and rub down, if you are staisfied with the result, finish with whatever topcoat paint you prefer. If there are still imperfections, repeat the filler/primer step.
Chris Lane
Postby Chris Lane » February 12th, 2012, 11:36 am
John - many thanks for that guidance. I was concerned about the keying of a primer as my previous experience with boat hulls was problematic!
John Rickett
Postby John Rickett » February 12th, 2012, 2:03 pm
Chris,
I've not had a problem with this method, it possibly depends on which release agent was used. I make most of my own grp parts now using Meguiars release wax and found the parts clean up very quickly. Provided you are careful to thoroughly abrade the surface at the same time as washing off the agent, I'm sure you'll find the primer adheres well. Afew coats off hi-build primer should, when cut back, provide a lovely flat surface for painting.
Postby Mike Booth » February 13th, 2012, 8:07 pm
Highly reccomend you scrub the parts off with acetone or celly thinners first. I would also suggest 400 paper. Sorry to differ John but at 240 if there is any detail on the mouldings it's going to vanish PDQ.
Postby Phil Clark » February 14th, 2012, 6:31 pm
Another vote for Acetone, this will remove any residue left that water won't remove. (I always Acetone rinse all moulded parts we produce for Jerry Bates)
If the part has moulded detail, abrading with a fine scotch pad also works well.....they are a little less aggressive than wet & dry and being 'soft' they conform to the surface well and don't knock the edge of raised detail as much.
Chris Lane
Postby Chris Lane » February 15th, 2012, 7:09 pm
Unaniminity among the experts - magic! Thanks guys; I have both cellulose thinners and acetone so will use the acetone. Chris
