Needle roller bearings
Hugh Grant mbe
Postby Hugh Grant mbe » May 9th, 2012, 2:37 pm
Anyone have a source for roller bearings 40mm x15 mm x10mm
Peter Clare
Re: Needle roller bearings
Postby Peter Clare » May 12th, 2012, 12:58 pm
Hi Hugh , I can't visualise the bearing you are looking for but a good starting point is the on line catalogue of Simply Bearings ( at Leigh in Lancs). Tel 01942 269837 . From this you will be able to describe and dimension your bearing the way the bearing suppliers list it. They supply from bargain basement to top quality bearings, so if they can match the size you need they will supply it at a sensible price. Regards. Peter Clare 3057
Robin Woodhead
Postby Robin Woodhead » May 21st, 2012, 6:44 pm
Hi Hugh, Not sure what you need but have a look on this web site, I have used them in the past; they are good.
http://www.technobotsonline.com/bearings/needle-roller-bearings.html
Robin
Alan King
Postby Alan King » June 29th, 2012, 9:55 pm
hi Hugh
this is quite an odd size for a roller you may need to use a spacer or shim on outer of a smaller bearing what are these for?
Users browsing this forum: No registered users and 50 guests
