ZDZ100 B2 RV Ignition Unit Advice Please
Matt Harrowven
Postby Matt Harrowven » May 13th, 2012, 8:15 pm
Folks,
I have a ZDZ100 B2 RV. It needs a new ignition unit, the one that came with it (a Falkon PCI 2.3 80ccm) is broken, only one lead is firing. Now a genuine replacement unit is £170, and then I'm told I need a new prop driver (another £20) cos the magnet in the newer Falkon units is the other way round.
Would a RexCel or DLE 111 unit work (around £60) with this engine? Or is the Falkon unit a 'special' unit I have to shell out for?
Does anyone ever done this with this particular engine?
Many thanks for your help.
Matt H
LMA 3066
LMA No. 3066
Re: ZDZ100 B2 RV Ignition Unit Advice Please
Postby Tony Collins 1073 » May 13th, 2012, 9:42 pm
Matt, if it is possible to open the unit up, I might be able to repair it for you.
Matt Harrowven
Postby Matt Harrowven » May 13th, 2012, 10:21 pm
Hi tony,
Yes, when I got it, the unit had already been opened up and taped back together.
I know it's the unit that's faulty as the 'good' lead will happly run either cylinder.
It'd be ace if it could be repaired, I had a looksee but couldn't see anything untoward, but I know nothing about electrics!
If you PM me your address I'll post it off. Do you need just the unit?
Mat
LMA No. 3066
Postby Tony Collins 1073 » May 14th, 2012, 7:30 am
E-mail sent Matt.
