Postby Alan King » June 28th, 2012, 9:35 pm
This project has been around a while, i have now aquired it and registered it, plane will come out about 25kg, wingspan is 12 foot, fibreglass fus, foam core wings, i have started to fit the purpose built retracts ( not my work ) and have adapted some air cylinders to fit the units, wheels are purpose built ( by me) and the tyres are from light aircraft tailwheel 150mm diameter.
This is a model of the HU16a which had a shorter wing, slightly different ailerons and smaller rudder and tail plane than the upgraded HU16B which had it wing extended just outboard of the engine nacelles.
i understand that this plane is a sister ship to Dr Jeremy Shaws, this plane though will be amphibious, if all goes as planned it will be powered by two purpose built 90cc 9 cylinder radials.
I have epoxied the underside of the centre section of the wing and am planning within the next few weeks to have all wings done and ready for inspection before painting.
hope you enjoy the pics
- full view
- DSCF6368 3999x2999 Medium Web view.jpg (36.42 KiB) Viewed 16607 times
- retract detail
- DSCF6369 3999x2999 Medium Web view.jpg (50.46 KiB) Viewed 16607 times
- retract
- DSCF6370 3999x2999 Medium Web view.jpg (46.47 KiB) Viewed 16607 times
- DSCF6371 3999x2999 Medium Web view.jpg (57.06 KiB) Viewed 16607 times
- DSCF6372 2685x2996 Medium Web view.jpg (68.39 KiB) Viewed 16607 times
