Hi Guys. I started this project about 8 years ago - I don't like to rush..... I was after a twin edf model that was a little different and came across the CessnaT37. I couldn't really find much information about it but did come across a small airfix equilvalent of about 1/72nd scale in an rc model shop whilst on holiday in America. The web describes it as such....
The Cessna T-37 Tweet (designated Model 318 by Cessna[2]) is a small, economical twin-engine jet trainer-attack type aircraft which flew for decades as a primary trainer for the United States Air Force (USAF) and in the air forces of several other nations. The A-37 Dragonfly variant served in the light attack role during the Vietnam War and continues to serve in the air forces of several South American nations.
I made up some plans...plans might be an overly grand description and got to work to frame up the fuselage with a small amount of planking.the fuselage includes up to just outside of the engines with the outboard section of both wings plugging into carbon fibre tubes and a full height wing spare. The top side of both wings, the tailplane and the rudder are all sheeted with the thin fibreglass sheeting supplied by Mick Reeves - Pro skin. The model will be about 70 inch span and will have 2 75mm fan units probably running off 5S packs. I haven't quite decided yet if i will fit retracts. This weeks work, the first in a very long time will be to sheet the fuselage and get a rigid structure. It's a little flimsy still at the moment but getting stronger all the time. As time passes i will add some more pictures.
- HPIM1026 2.jpg (75.67 KiB) Viewed 21518 times
