jet tronic dual j valve
BRIAN RAWCLIFFE
Postby BRIAN RAWCLIFFE » March 3rd, 2009, 6:47 pm
Has anybody had any problems with a jet tronic j valve.I have one that when it is in the down position it leaks air,in the up it's ok unfortunately they are a sealed unit so you can't see the piston/solenoid working.Any info will be appreciated.
Thanks. Brian Rawcliffe 1669
BRIAN RAWCLIFFE
Re: jet tronic dual j valve
Postby BRIAN RAWCLIFFE » March 4th, 2009, 9:16 am
Problem cured,i removed a blank plug and squirted some Pitstop ptfe into the port operated it a few times and it is now ok.
Probably freed the O ring .Brian.
