Ron Pearman wrote:Your use of full flap is possibly producing the opposite effect to that you want, drag not lift. I don't know what your full flap setting is but normally max take off lift is achieved with about 12 to 15 degs of flap.
pete.pitt wrote:Just test flew my YT bronco,C g as stated in the instrutions, power is 2x 22 zenoa ,it took along time to rotate and that was with full flaps deployed, 230yds think the cg is to far forward at 129mm any one tryed this model at a more reward cg? plenty of power ,with out flap would not rotate ,when flaps were up she dropped her nose but i could trim it out.
Alan Cantwell 1131 wrote:contact Andy Johnstone, he flew one for a while, sounds to me like its nose heavy, what was it like when you go the flaps up?
Phil Clark wrote:If it's fine one in the air but needs up trim and you have no elevator authority to flare (or to rotate on take off), then yes, it's nose heavy. Shift it back 1/2" and dry again............
Thanks Phil will give it a go
andy johnson wrote:Hi Pete , I had my C+G back at nearly a 1'3 of the wing ,the instructions is to far forwards ,but you need to have a lot of elevator movement as when you slow it down to land the elevator is out of the prop wash and becomes dead . When I used the flaps it put the nose up so I had a mix giving down elevator when using the flaps .Mine was powered by 2 zenoah 23's and had loads of power and could fly round just on 1 engine.If you need any more info you can ring me on 07768855723.
Andy
pete.pitt wrote:andy johnson wrote:Hi Pete , I had my C+G back at nearly a 1'3 of the wing ,the instructions is to far forwards ,but you need to have a lot of elevator movement as when you slow it down to land the elevator is out of the prop wash and becomes dead . When I used the flaps it put the nose up so I had a mix giving down elevator when using the flaps .Mine was powered by 2 zenoah 23's and had loads of power and could fly round just on 1 engine.If you need any more info you can ring me on 07768855723.
Andy
Chears Andy Will move mine back the same as yours
