Postby Phil Clark » December 9th, 2012, 11:36 pm
Dean
If the handles are purely cosmetic, then I'd shape them from Chemiwood (the link I sent you via e-mail)
If you want them to be functional and used to hold to open & close the canopy, you may want something more substantial. Chemi is great to work with using small hand tools and parts like this can be shaped easily, but in small sizes, it's quite brittle. For something more robust, I'd use glass fibre board. It's generally available in 1/16", 1/8" and 1/4" thicknesses and though very tough (destroys bandsaw blades very quickly), once rough cut to shape, it's easily shaped/finished with something like Permagrit needle files.
This is how this functional cockpit door handle on this 1/4 scale Spitfire cockpit door was done......
- Mk1Spit_299.jpg (25.07 KiB) Viewed 8159 times
- Mk1Spit_313.jpg (37.26 KiB) Viewed 8159 times
- Mk1Spit_314.jpg (37.57 KiB) Viewed 8159 times
