Dual battery setup
mark houghton
Dual battery setup
Postby mark houghton » May 18th, 2013, 8:39 pm
Hi all
I'm after some advice as to which dual battery setup you are all using, I'm planning to use two 3700 mah NiMH
or two 2s LiFe with a Futaba 617fs receiver with a maximum of 8 hitec 645mg servos the unknown being what type of switch do I go for? any help would be welcomed
Cheers Mark
Joshua Henderson
Re: Dual battery setup
Postby Joshua Henderson » May 20th, 2013, 7:51 am
I have just completed a 50 cc yak and a 100 cc extra.
I haven't flown either model yet but they are set up as follows
50ccer-
2x 2200 mah 6v rx packs and a 4.8v ign pack
They were setup on two jr heavy jr switches, the batteries plugged into the switch and then the lead that went to the rx had a diode to get the voltage to 6v and also give proper redundancy as the batteries went into 2 channels and were properly isolated in the event of a short circuit etc as the good battery couldn't be dragged down cause the diodes drop voltage and also act as a one way valve.
However upon range testing I was getting some really weird results (using a flight logger)
There were absolutely no frame losses on any of the satellites but instead it was going straight to a hold.
I changed the orientation of the satellites and no better. However it is impossible to go straight to a hold.
So I investigated further, checked all wiring, and I ended up with a pair of dodgy switches. One was only giving a output of 4v even minus diode, and the other had a short in the plug. Effectively it was operating on one battery at 4v.
Since that experience I have removed all switches in all of my petrols and turbine, and for now will plug straight in, but do research on jack plugs as switches.
The 100ccer is setup on a powersafe rx with 2lipos and two regs. Again plugging straight in.
I don't trust switches at the minute and I'm researching jack plugs as a alternative
Just my 2cents
And hope it helps
Josh
Postby John Greenfield » May 20th, 2013, 8:50 am
Mark
Give me a call to discuss. I can fix you up with the switches, diodes etc just like I fit in my models.
Postby Bob Thompson1894 » May 20th, 2013, 9:58 am
The ultimate bling? Nice piece of kit, though. http://www.youtube.com/watch?v=DJEz2jFLuOQ
Postby sean smith » May 20th, 2013, 5:36 pm
I use SM Services Powersave (Split supply) on my P47 with four heavy duty switches.
Sean.
Postby Bob Thompson1894 » May 20th, 2013, 6:12 pm
sean smith wrote:I use SM Services Powersave (Split supply) on my P47 with four heavy duty switches.
Sean.
SM also do a neat battery backer for £14, which isolates a faulty battery.
Postby sean smith » May 20th, 2013, 6:29 pm
Sean.
I think that the powersave unit has this built in. I run two RX batteries and two servo batteries via the unit so any one of the four switches or batteries can fail without me losing control. Another good thing is the power for the servo's comes direct from the unit and doesn't have go via the RX.
Sean.
mark houghton
Postby mark houghton » May 21st, 2013, 2:39 pm
THANKS ALL FOR THE ADVICE I DECIDED TO TAKE JOHN UP ON HIS OFFER
A SIMPLE SETUP WITH EXCELLENT CONPONENT QUALITY AND AN
EXCEPTIONAL TRACK RECORDN
CHEERS MARK
