Spektrum ds8
paul hughes
Spektrum ds8
Postby paul hughes » May 29th, 2013, 7:06 pm
I have a minor problem with my DX8, when I turn on the tx and then RX some of the servos move to there full travel for a second or two. This even happens with the ATVs reduced, it has caused a stripped servo gear and I think it is to blame for 2 ailerons to be pulled loose. Has anyone else come across this problem or does anyone know how to stop it. cheers.
Chris Bradbury
Re: Spektrum ds8
Postby Chris Bradbury » May 29th, 2013, 7:40 pm
Sounds like a bind issue.
Try disconnecting all the servo arms to avoid binding when doing this, but connect all the servos to the receiver and bind with them all plugged in. This has worked for me in the past.
BMFA Examiner
