Balancing a Sky 120
RichardVaughanDavies
Balancing a Sky 120
Postby RichardVaughanDavies » July 9th, 2013, 1:32 pm
My Sky 120 is finished and has had her maiden flight. Geoff, who took the maiden, said she flew very well and he was impressed. I was chuffed to bits :D
So, his comments were:-
Bit more throw on the elevators ... an extra 5mm added
Bit more throw on the rudder ... ditto
Felt a bit nose heavy ... This is true, when I checked the balance, she was slightly nose heavy, but only slightly. Back in the workshop, and with the help of my beautiful assistant, 70g of lead on the tail made her DOBA (Dead On Balls Accurate ..... name the movie :) )
My question is (finally I hear you sigh), do I fit 70g to the back end of the fuselage where it will stick out like a sore thumb, of fit 300g inside the main mid-section of the plane? Dry weight of the plane is 8.6Kgs, so would that extra 300g make a lot of difference?
Your thoughts would be appreciated.
Richard
Dave Collis 2296
Re: Balancing a Sky 120
Postby Dave Collis 2296 » July 9th, 2013, 1:47 pm
Is it possible to move some of the internals, (battery etc.) rearward instead of adding weight?
If you have to add weight to the rear, could you put it under the tailwheel mount? Not quite so visible?
Dave.
Postby RichardVaughanDavies » July 9th, 2013, 2:46 pm
The battery is towards the rear, under the hatch thingy on the right hand side in the picture. It was here I was thinking of putting the weight.
Taken a few months ago.
library pic mid section.jpg (70.41 KiB) Viewed 4248 times
Postby John Greenfield » July 10th, 2013, 6:25 am
Get some sheet lead and bolt it under the tail wheel mount using the tail wheel fixing bolts / screws to hold it in place. It does not matter what the size of the model, it is a fact that lighter models fly better.
Postby RichardVaughanDavies » July 10th, 2013, 11:03 am
Thanks for the input guys, and I'll go with the weight bolted onto the tail wheel assy.
I've being doing a bit of testing and it doesn't look out of place.
Thanks again
Richard
