push rods
john lucas
push rods
Postby john lucas » October 23rd, 2013, 6:48 pm
I am looking for American size 0.93inch / 2.3mm which I believe is 13swg for a P47. The nearest I can get to the size is 12swg. If possible I would like to get the American size as 12swg is a little to tight for the push rod tubes. The wire needs to 48" long. I have tried soldering M3 ends to the American wire but are unable to get the solder to take to the wire even using flux and cleaning with emery cloth.
Re: push rods
Postby sean smith » October 24th, 2013, 6:35 am
Hi John,
I used 48" 4-40 steel push rods on my 109 with M3 threaded ends brazed on both ends.
Du-Bro in the US do them but i think my ones were Great Planes.
48" Threaded Rod (4-40)#891
48" long (1220mm) .093 rod 4-40 thrd. 24/tube.
USD$ 1.79
Sean.
john lucas
Re: push rods
Postby john lucas » October 28th, 2013, 1:51 pm
Sean
thanks for the info, I will it a try.
Users browsing this forum: No registered users and 84 guests
