1/5 scale Aero-Commander 117"
Steven Weir
Postby Steven Weir » November 28th, 2013, 8:52 pm
Hi all just thought I would give you an update on this models progress. Have added a few pics
to look at.
First of the formers on plan all scratch, photocopied from plan cut out stuck to wood then cut the wood.
Picture 060.jpg (189.86 KiB) Viewed 14499 times
Last edited by Steven Weir on November 28th, 2013, 10:45 pm, edited 1 time in total.
Steven Weir
Re: 1/5 scale Aero-Commander 117"
Postby Steven Weir » November 28th, 2013, 9:11 pm
ooooops making a hash of this will try again when I have resized my images.
inner wing checked for fitting aligned up nicely just have to build the other side now.
Picture 314.jpg (60.39 KiB) Viewed 14490 times
Last edited by Steven Weir on November 28th, 2013, 10:48 pm, edited 1 time in total.
Steven Weir
Postby Steven Weir » November 28th, 2013, 9:55 pm
Just a few more pics I hope. Coming on hopefully will be finished end of next year.
few more formers in place
Picture 062.jpg (54.76 KiB) Viewed 14478 times
Picture 067.jpg (57.86 KiB) Viewed 14478 times
first of the robart 90 degree retracts fitted
Picture 162.jpg (57.85 KiB) Viewed 14478 times
looking down on cabin note topside windows as per original aircraft.
Picture 163.jpg (46.19 KiB) Viewed 14478 times
veiw from side showing cabin windows and seating cabin is illuminated. and has a drinks table centre rear.
Picture 164.jpg (63.14 KiB) Viewed 14478 times
adding sheeting to front and rear of forward fusealarge
Picture 165.jpg (60.55 KiB) Viewed 14478 times
Picture 169.jpg (64.26 KiB) Viewed 14478 times
Last edited by Steven Weir on November 29th, 2013, 1:07 pm, edited 1 time in total.
Steven Weir
Postby Steven Weir » November 28th, 2013, 10:40 pm
Hi all sorry for the picture quality and the state of my tiny workshop ie single garage
looks better in real life than on photo's second inner wing under constuction then I can get
the diahedral correct for fitting to the fusealarge, inner cabin lighting came from a decortive bowl light set from B & M store at a cost of £3.50 for a set of 12, bright L E Ds, good value 4.5vdc. Model will also have a full nav light kit and full landing light kit 4 off. Still a lot of work to do as you will all know lot's of sanding, when finished will cover in Solarplex unless anybody knows of anything better. Did think about spraying the whole model but not sure. I might not be as good as some of you guy's at building but I take my time double check everything and make sure it all fits ok before any glueing, I think this model will turn out ok, proof will be in the flying, and have tried to keep as close to the original aircraft design inside and out, happy flying all and thanks for looking.
Postby stewart clifford » November 29th, 2013, 9:38 am
Never seen one of these before, is it your own plan?
Steven Weir
Postby Steven Weir » November 29th, 2013, 1:04 pm
Hi Stewart, Not my own plan, from Palmer plans, from the State's, taken from a real aircraft which my uncle used to fly in the late fifties early sixties, commonly now known as the Shrike, made in the USA, Check out Bob Hoover's Aero Commander u tube videos some crazy flying with both engines off, including low passes, Excellent pilot just nuts. Have fun and thanks for looking.
Last edited by Steven Weir on November 30th, 2013, 3:02 pm, edited 1 time in total.
Steven Weir
Postby Steven Weir » November 30th, 2013, 2:15 pm
Thought I would put photo of finished model on so you can all see what it will look like . This is not my model but one similar, nice model. Thanks for looking.
Steven Weir
Postby Steven Weir » September 26th, 2014, 1:54 pm
Tail section nearly complete.
Steven Weir
Postby Steven Weir » September 26th, 2014, 2:03 pm
View of cockpit lighting at night.
Steven Weir
Postby Steven Weir » September 26th, 2014, 2:04 pm
Cockpit lighting.
Ret Vinsent
Postby Ret Vinsent » January 29th, 2015, 5:34 pm
I am really thrilled with the result, especially the results of 3 last photos, everything is expressed in details, every small ones are perfectly made and Aero-Commander seems to be unimaginable, your work deserves praise, I wish I will be patient enough to perform my own project and also have such imprassive results!
Serj Odin
Postby Serj Odin » March 5th, 2015, 6:20 pm
my jet commander ...
Steven Weir
Postby Steven Weir » April 7th, 2015, 2:19 pm
Ret Vinsent wrote:I am really thrilled with the result, especially the results of 3 last photos, everything is expressed in details, every small ones are perfectly made and Aero-Commander seems to be unimaginable, your work deserves praise, I wish I will be patient enough to perform my own project and also have such imprassive results!
Hello Ret, many thanks for your comments and pleased that you like this model, lot's of luck making yours. I have tried to make this one as close to the original plane, very hard to do. Are you doing yours from plans or from kit. Will put more pics on soon.
Steven Weir
Postby Steven Weir » April 7th, 2015, 2:22 pm
Serj Odin wrote:my jet commander ...
Hello Serj, Your Commander looks impressive and look forward to seeing some more photo's
good luck with the build.
Users browsing this forum: No registered users and 51 guests
