A lot of the balsa stringers are now in the fuzz ,the top hatch now needs cutting out so I can get inside to fit the engine and fuel tanks , once I done this I can order the tail pipe for the engine , I am putting the engine as far forwards as possible to help with the C+G also I have room to fit 2x 2 litre tanks on the C+G , the nose section has been left open until I get the retract unit .Most Vampires come out very tail heavy so I’m trying hard to get all the weight as far forwards as I can .
I intend to get inside the fuzz with a cutting disc to remove as much unneeded wood as I can behind the C+G ,I intend to fly it on a Wren 160 so I need to keep control over the weight where I can.
- IMG_0929.JPG (26.4 KiB) Viewed 30933 times
- IMG_0928.JPG (23.05 KiB) Viewed 30933 times
