Z38 problem.
Z38 problem.
Postby Bob Thompson1894 » May 31st, 2014, 8:24 am
Had running problems for some time with a couple of Z38s, and last week discovered this with one. Anyone seen this before, or have a clue whats going on?
Re: Z38 problem.
Postby Alan Cantwell 1131 » May 31st, 2014, 11:46 am
thats aluminium, crank or pully bent, and its effectively skiming the flywheel down and yes, seen it before, remove the plug, grip thevengine mount in vice, and check the propdriver, see if is runnig true, a clock would be best, but a sile pointer will do, if you can fix one up,
Re: Z38 problem.
Postby Bob Thompson1894 » May 31st, 2014, 1:38 pm
Ah! I thought it did not look true when running. Its not had a hard bump, thats why I was unsure about the crank. Is it a new crank then Alan?
Re: Z38 problem.
Postby Alan Cantwell 1131 » May 31st, 2014, 2:04 pm
maybe, maybe not, sometimes, if its the flywheel thats got hit, it will bend the crank at the taper section, and the flywheel, sometimes, this can be skimmed in situ, after repairing the crank displacement as to as good as it can be done, state, there is a charge, but the good news is, even if it takes only 1 hour, or 20, no fix, no charge, just return post i have sent more details by PM
Re: Z38 problem.
Postby sean smith » May 31st, 2014, 2:20 pm
Bob,
Send the bits to Alan he will sort it out for you if it can be sorted? Alan fixed a similar problem on my 38.
Sean.
Re: Z38 problem.
Postby Alan Cantwell 1131 » May 31st, 2014, 3:17 pm
and his was a bitch, but, it got sorted :D
Re: Z38 problem.
Postby Bob Thompson1894 » May 31st, 2014, 3:20 pm
PM your address Alan. I have a new mag on order from Glens, be a shame to bugger that one! Ta mate.
Re: Z38 problem.
Postby sean smith » May 31st, 2014, 4:13 pm
Alan Cantwell 1131 wrote:and his was a bitch, but, it got sorted :D
Yeah glad i wasn't paying for it :D
Andy Macqueen
Re: Z38 problem.
Postby Andy Macqueen » June 9th, 2014, 11:23 pm
I wouldn't hold your breath ordering from glens models,ive had some Da 150 reed valves on order for 14 months,after receiving conformation of the order and a handfull of emails later im still waiting.....Wtf
Peter Smedley
Re: Z38 problem.
Postby Peter Smedley » June 14th, 2014, 5:42 am
Toni-Clark in Germany gives good service for zenoah bits :D
Steve Rickett 2333
Re: Z38 problem.
Postby Steve Rickett 2333 » June 14th, 2014, 10:35 am
Andy,
That doesn't sound like Glen at all. Have you called him?
Re: Z38 problem.
Postby Bob Thompson1894 » June 18th, 2014, 11:02 am
Just got back from Corfu, had an email from Glen that he has had to order the mag in.
Re: Z38 problem.
Postby Alan Cantwell 1131 » June 18th, 2014, 5:11 pm
and i have sorted the crank, skimmed the flywheel, and now i am back at work, i will fit a woodruff key, (missing) check it out, and get it back to you
Re: Z38 problem.
Postby Bob Thompson1894 » June 18th, 2014, 6:57 pm
cheers Alan. Bet Glenn (Masters) has nicked it! He dismantled the engine for me. (well, dont want my hands all mucky, now do I?) Did you look at the mag?
Re: Z38 problem.
Postby Alan Cantwell 1131 » June 18th, 2014, 8:37 pm
mags toast, its had quite some heat through it, mag was a mess, but has skimmed up ok,
Re: Z38 problem.
Postby Bob Thompson1894 » June 18th, 2014, 9:10 pm
OK mate. Cost what you quoted? Postage?
Re: Z38 problem.
Postby Alan Cantwell 1131 » June 18th, 2014, 9:48 pm
not finished, mounted and texted yet, only when i am satisfied will it go back to you
Re: Z38 problem.
Postby Bob Thompson1894 » June 19th, 2014, 8:13 am
ok, ta.
Re: Z38 problem.
Postby Bob Thompson1894 » July 8th, 2014, 6:13 pm
Alan- are you getting my messages? Sent you one just now. Not sure if they are going. I emailed you the other day too.
Re: Z38 problem.
Postby Alan Cantwell 1131 » July 8th, 2014, 7:30 pm
recieved and replied to Bob
