Giles 200
Brian Bellamy
Giles 200
Postby Brian Bellamy » June 10th, 2014, 2:03 pm
Could anyone confirm if hitec servos 545bb has enough power for the wing aileron, I have one per wing fitted, the Gilles is a 1/3 scale 98 inch span with a 3w100 engine.
Thanks Brian
steve stuttard
Re: Giles 200
Postby steve stuttard » June 10th, 2014, 4:28 pm
this is the spec for that servo , but it also depends on how much mechanical advantage it has ,, but my first thoughts are NO , if it were me i would put a 5645 and use a LiFe battery
Modulation: Analog
Torque: 4.8V: 61.1 oz-in (4.40 kg-cm)
6.0V: 76.4 oz-in (5.50 kg-cm)
Speed: 4.8V: 0.22 sec/60°
6.0V: 0.17 sec/60°
Weight: 1.57 oz (44.5 g)
Dimensions: Length:1.56 in (39.6 mm)
Width:0.77 in (19.6 mm)
Height:1.41 in (35.8 mm)
Motor Type: 5-pole
Gear Type: Plastic
Rotation/Support: Single Bearing
robbieskipton
Re: Giles 200
Postby robbieskipton » June 10th, 2014, 5:26 pm
noooooooooooooo, it will fall out of sky faster than it went up. As rule of thumb in 100 cc aerobats you need all metal geared servos, 20 kg and above for that model ideally you need 2 servos per aieleron of 15 kg each, say jr 8511 or equivelant or if you are only going one servo you need 25kg jr 8911 or equivelant. this will give plenty of authority. all other surfaces need the same sort of power. I had a 100cc giles 202 my set up was 2x jr 8911 per aileron, 2x jr 8511 per elevator and 3x jr 8511 for the rudder through a powerbox champion. you need loads of capacity for a 100cc 30% scale aerobat.
www.bmdsigns-wraps.co.uk
www.Skipmodeldesigns.co.uk
Brian Bellamy
Re: Giles 200
Postby Brian Bellamy » June 11th, 2014, 6:56 am
Thanks for the replys, only just getting back into model aircraft after 30 years, and having bought this I thought that the servos were under sized so will look to replace them.
Thanks Brian
Brian Bellamy
Re: Giles 200
Postby Brian Bellamy » June 20th, 2014, 8:04 am
Hitec HS-7955TG servos at 6 volt now being installed
robbieskipton
Re: Giles 200
Postby robbieskipton » June 21st, 2014, 3:36 pm
Thats plenty, just watch linkage slop and also dont use their standard plastic output arms, not up to it im afraid.Alloy jobbies are best for that application with 3mm ball links and 3mm allthread as a good standard, at least you can be assured that the control department is sound and wont let you down.
Brian Bellamy
Re: Giles 200
Postby Brian Bellamy » June 24th, 2014, 4:20 pm
Do you use a step battery supply for the servos, rather than just through the reciever, if so what is the best set up
Allan Griffiths
Re: Giles 200
Postby Allan Griffiths » June 25th, 2014, 8:37 pm
Depends on your radio being used.
If futaba then you can use the new high voltage RX
Another option is to look at a power box. you will use two batteries duel regs etc all in one unit.
Some links here of one which would suitable.
http://www.powerbox-systems.com/en/prod ... ution.html
Brian Bellamy
Re: Giles 200
Postby Brian Bellamy » July 28th, 2014, 11:02 am
The giles has a 3w100 twin in it, just found that there is no spark, anyone know how to test the ignition unit on these.
Thanks Brian
Brian Bellamy
Re: Giles 200
Postby Brian Bellamy » August 12th, 2014, 10:16 am
Spark problem was ignition unit, just fitted a rcexl unit, anyone know the correct degrees tdc for the engine timing.
Thanks Brian
Peter Clare
Re: Giles 200
Postby Peter Clare » August 12th, 2014, 4:03 pm
Static timing for Rcexl ignition is 28 degrees Before Top Dead Centre. The ignition unit has built in auto advance so you don't want to set it more advanced than this stationary. If you find that the engine kicks back too much when starting you can retard it a bit but it should be OK
Brian Bellamy
Re: Giles 200
Postby Brian Bellamy » August 12th, 2014, 4:16 pm
Thanks for that Peter, I will set it at 28 and try it.
Regards Brian
Brian Bellamy
Re: Giles 200
Postby Brian Bellamy » August 12th, 2014, 7:34 pm
Timing setup and engine running spot on. Getting close to flying it soon.
Brian
