interference ??
scott wood
interference ??
Postby scott wood » May 10th, 2009, 8:17 pm
hi all i have just bought a cap 232 (black horse) with a zenoah 62 (electric ing (bcm) has pcm rec and opto
the problem is after 2 to 3 mins of engine running the rudder and ele starts to twitch very violently have tried removing opto , changed xtal etc the fault continues with engine running but stops as soon as engine killed
my question is can i earth the ing unit to the engine ? if so is it a matter of just bolting a wire between the to ?
thanks in advance
scott
lma member :D
scott wood
Re: interference ??
Postby scott wood » May 13th, 2009, 6:59 pm
hi all
sorted with a couple of ferrite rings and a faraday cage around the ing unit all well at the moment
thanks to paul and keith for your help
:D bring on the sun
