DB SE5 powerplant
DB SE5 powerplant
Postby Alan Cantwell 1131 » July 3rd, 2014, 5:59 pm
could i ask the catton guys, what do they use to power their DB SE5s, i bought a nice example at weston park, the old 1piece wing version, with the intent of fitting a zenoah 38' but it would need much modification to take this motor, looks like it may have had a standard engine mount fitted, i have zenoah 23s, mvvs 160s, a 3w 20, and, if i must, a new unrun stovepipe laser 150, not used a glow fuel motor for a while, oh god, ive become a richard
Re: DB SE5 powerplant
Postby Bob Thompson1894 » July 3rd, 2014, 8:01 pm
My mate had a Ryobi 32cc in his. I have one if you want) Was perfect. However, that would be a similar mount to the Z38. Any news on mine, Alan?
Postby Alan Cantwell 1131 » July 3rd, 2014, 8:41 pm
Bob, i cant get near the machine, and its my ruddy machine, job will be clear by tuesday, sorry, i also have 2more in the que,
Paul Savage 1568
Postby Paul Savage 1568 » July 3rd, 2014, 9:57 pm
Alan.
Most of our SE5's are indeed fitted with a Zenoah G38 but as you rightly pointed out, there is quite a lot of major surgery needed to the main firewall in order to get them in.
If you can get your hands on any of the newer compact DLE CRRC AGM 30 cc, 35cc or even 40cc type of engines then any of them will do the job very well and can be persuaded to fit onto the original firewall.
Hope this helps.
Paul.
Postby Bob Thompson1894 » July 3rd, 2014, 11:09 pm
thanks Alan. No problem.
Postby Alan Cantwell 1131 » July 4th, 2014, 6:26 am
many tjanks Paul, buying a new motor is not an option, i can see surgery being committed :?
Mike Parslow
Postby Mike Parslow » July 21st, 2014, 8:46 pm
i have a DB se5a with a zenoha 26 in it and flys fine now you say you have a 3w 20 this may do the job depending on the weight of the plane and the size of prop the 3w will turn.. Zenoah 26 on a carbon 18*8 is perfect so if a 3w can turn the same prop at 7800 -8000 rpm there should not be a problem
Users browsing this forum: No registered users and 111 guests
