Wing Fixing on Parasol Plane
Steve McDonald
Postby Steve McDonald » July 21st, 2014, 2:06 pm
I was given this aircraft with a view to the owner seeing it fly, very generous. However I have a query. There are two wing joiners for the wings to slide onto and struts underneath as fixings, there is no other fixing for the two wings and there is no reinforcement at the roots where I could screw a plate onto and the wings move a bit at the centre section. I don't want to screw into the top and bottom spars for fear of compromising the structure. The end on shot shows the standard configuration of the wing. Surely it's not just the lift under the wings that hold them in place! I don't know what the aircraft is but believe it was built from an American plan. Any advice would be most welcome, both on what to do to fix the wings securely and on what type of aircraft it is.
Front View.jpg (372 KiB) Viewed 1890 times
Side Above.jpg (255.94 KiB) Viewed 1890 times
You can see the standard wing construction
Side View 1.jpg (287.22 KiB) Viewed 1890 times
No reinforcement
Wing Top.jpg (153.22 KiB) Viewed 1890 times
Again, no reinforcement
Wing Underside.jpg (165 KiB) Viewed 1890 times
