Compression springs
Mike altham
Compression springs
Postby Mike altham » August 15th, 2014, 10:19 am
Does anyone know where I can get two compression springs from? Need to be able to slide over 3mm threaded rod (3.5mm) and about 20mm long. Need to be quite strong as they are going to be on the nimrods nose leg servo saver.
Nigel Cox
Re: Compression springs
Postby Nigel Cox » August 15th, 2014, 5:55 pm
I've got a box of assorted springs from Halfords ( code HBB134) there's a couple that might be suitable just depends if they will be stiff enough
edit: To compress them by 50% takes 280 ~ 350 grams
paul needham
Postby paul needham » August 15th, 2014, 8:16 pm
Users browsing this forum: No registered users and 64 guests
