design is better than the original
well here it is home made barrel exhaust and just of the braising station gaskets cut and fitted
still some fine tuning and clean up to do
second end cap went better than the first one
used durafix welding rod, takes a little practice to get rite, but it all came together in the end
had the header cnc'ed plus spacer
left the baffles out this time going to build another MK2 with baffles and it will in stainless and silver soldered
engine is still a virgin, not run or set up, need a little help with that part any takers?
would like to try to get engine running this weekend just got to set up the throttle curve
comments welcome
- 20140904_203320.jpg (205.63 KiB) Viewed 3343 times
- 20140904_203332.jpg (151.15 KiB) Viewed 3343 times
