32m Wing Tube
Chris Hurst
32m Wing Tube
Postby Chris Hurst » August 27th, 2014, 8:42 pm
Can anybody suggest where I can get either an aluminium or carbon 32mm wing pole?
I need it to be 781mm long so, to ask a daft question, what is the best way of nicely cutting to length? Carefully with a hacksaw and file or is there a better way?
Many thanks.
Peter Smedley
Re: 32m Wing Tube
Postby Peter Smedley » August 30th, 2014, 2:39 am
Carbon copy do some tubing. To make a square cut wrap a sheet of A4 paper around it keeping the sheet edges all in line. That will give a straight edge. I use a bandsaw. If you don't have one then it's a hacksaw or Dremel.
Mike altham
Re: 32m Wing Tube
Postby Mike altham » September 3rd, 2014, 8:03 pm
Yep cc do them but if it's an odd size graphtech in the USA or pbg composites in New Zealand they hand make them and grind them to size. What we use on the 40% imac models.
