Meister Zero
Meister Zero
Postby David Brown » August 30th, 2014, 7:11 am
This is not such a new project but a slow build over about 2 years, I had it ready to fly (in primer) a while back but due to it being blown off its trestles & wrecking the cowl etc along with damage to the Moki 150 I lost interest. I am now back on with it with some help & enthusiasm from fellow club members. I have just finished refitting the cowl mount plate & engine module along with the cowl flaps. Its just the sliding cockpit (another mod) to finish then it will be again ready to test fly.
Spitty 005.JPG (128.28 KiB) Viewed 8133 times
zero 001.JPG (118.08 KiB) Viewed 8133 times
zero 002.JPG (115.12 KiB) Viewed 8133 times
zero 003.JPG (171.9 KiB) Viewed 8133 times
zero 004.JPG (169.76 KiB) Viewed 8133 times
david clarke
Re: Meister Zero
Postby david clarke » August 31st, 2014, 5:35 am
Nice to see this one progress Dave,seem's like you've had this one kicking about since god was a boy. :lol:
Re: Meister Zero
Postby David Brown » September 11th, 2014, 3:13 pm
Well after two years on this build she has finally flown. I had a few teething problems and a change in balance but it all came right in the end. The Moki 150 ran faultlessly with the best sound track out both slow & flat out. I managed 4 of the 6 test flights with only a service on the engine after the third flight. I want to try the 3 blade prop on the next flights. Flaps needed down elevator mixing in and they made all the difference to the landings. All up flying weight is 52lb, radio is Weatronic dual receiver. Steve took some video of its flights so I will post on utube when I sort them out.
Zero 001.JPG (219.59 KiB) Viewed 7927 times
Zero 002.JPG (227.83 KiB) Viewed 7927 times
Gregg Veasey
Re: Meister Zero
Postby Gregg Veasey » September 11th, 2014, 9:33 pm
Well done Dave. I best get my Zero out again for next year then. Did you not have the latest build instructions for it though as they say about the need for a down mix with flaps.
Re: Meister Zero
Postby David Brown » April 12th, 2015, 3:36 pm
Due to the good weather I have had chance to paint the Zero at last, just the cowl and gear doors to do now. Its the first time I have done flush rivets and I am pleased with the effect.
Zero paint 001.JPG (213.49 KiB) Viewed 7513 times
Zero paint 002.JPG (206.42 KiB) Viewed 7513 times
Zero paint 003.JPG (207.6 KiB) Viewed 7513 times
Zero paint 004.JPG (204.39 KiB) Viewed 7513 times
Zero paint 2 001.JPG (130.68 KiB) Viewed 7513 times
rob ellis
Re: Meister Zero
Postby rob ellis » April 12th, 2015, 5:18 pm
dave that looks terrific,,,i had one a few years ago & they fly like their on rails,..,,.good luck with it.,
Re: Meister Zero
Postby David Brown » April 13th, 2015, 7:01 pm
Cheers Rob, cowl painted this evening. getting there now. Its funny, when you don't need a shine it does. :)
Cowl 002.JPG (196.46 KiB) Viewed 7396 times
