Postby paul needham » October 11th, 2014, 4:46 am
please can anybody throw some light on problem.
the throttle and choke servos on my decathlon 'glitch' a lot when the engine is running, the choke sometimes to the point of making the engine cough and the throttle making it rev and back off momenterally.
The engine is a ZDZ90rvj
The servos are HS625mg on the throttle and HS635hb on the choke, both only done an hour at most.
The servos are fairly close to the ignition unit, mounted with the rubber grommets that come with them, reciver is a JR rd1222 powersafe with two 6volt batts.
After a run of possably fifteen minutes the servo cases are not hot.
The question is where to look first, is it radio, servos, vibration, heat or ignition ?
- DSCF7145 (Custom).JPG (297.08 KiB) Viewed 14216 times
