All that weight up the front is very good...but I am 100% certain that it won't be enough to get the balance point in the right location. With such a short nose, and a loooong sheeted tail I can admit defeat right now and accept the inevitable 1/2 a church roof of lead. With this in mind, I set out a very rough sketch of the airplane and the weights of key assemblies and used my rather no existant Maths skills to produce some moments. (head scratching moments mainly).
I won't bore you with the gory details but suffice to say that I estimate a whopping 5lbs of lead up the front to get the correct CG. Clearly this is only a guesstimate, but it gives me a rough idea and means I'm not so shocked later on! Securing such a large chunk of 'hardware' to a sharp and pointy nose is never going to be easy so I've elected to build some of the lead permanently into the structure. This way, it'll not take up any space, can't break loose and will give them impression that I've built this thing with only a tiny bit of ballast required (shhhh, don't tell anyone.)
So, that's two ounces shy of 3lbs epoxied into the void between the fuselage skins. It won't be enough...but it's a good start.
- IMG_4023.JPG (88.93 KiB) Viewed 139498 times
While fettling the fit of the formers I had to pre-assemble the two formers that make up the fuselage join. These are made from hard 1/4"balsa with 45 degree joins so that the grain is always traveling across the 'span'. 1/8" ply load spreaders were cut out by tack gluing four bits of ply together and then cutting them all out at once......
- IMG_4014.JPG (65.76 KiB) Viewed 139498 times
M4 blind nuts installed to the rear of the pair of formers and then installed in the fuselage. I've added some 1/16" packing between the formers to allow for some ply facing and also the thickness of the fiberglass and paint. It also gives me a bit of clearance for a hand saw when it comes time to chop the tail section off.....but I won't do that until the sheeting is in place.
- IMG_4019.JPG (101.05 KiB) Viewed 139498 times
