30% stearman
David Bell
30% stearman
Postby David Bell » January 6th, 2015, 7:26 pm
Could any member who has built a balsa usa stearman help.
I have just built a 30 % stearman (Not Balsa usa) and was wondering if you could help with the c of g location? The kit had no instructions as it is the first in the country from the worlds models.
Thanks for your help.
David Bell 3283
Tony Fagan
Re: 30% stearman
Postby Tony Fagan » January 7th, 2015, 1:31 pm
Hi David,
I have built a third scale Balsa USA Stearman using a 250 Moki engine. The Moki is very powerful and does add useful weight to balance the model on the suggested CG which is on line with the upper wings rear strut connection point, no additional weight was required. The torque effect of the Moki is very strong and mine does require side thrust and modicum of down thrust. Hope this is of some help.
