Yak 3-9 1/3 scale
Yak 3-9 1/3 scale
Postby Mike Booth » January 18th, 2015, 7:52 pm
I started work on a new display model on the 28th of October 2014 for this years season.
The Yak 3 was chosen as an under modelled Warbird which is now very popular in the fullsize airshow circuit , after a whole set of jigs,tooling and components were discovered in Russia a few years ago.
Thlis made it viable for the first time since the second world war for this aircraft to be reproduced for a modern market.
My model was conceived from my own drawings, cross referenced with scale data and cad data and digitising by Leon at Belair laser kits.
This made the whole process swift and i have to say the cutting based on my advanced construction has been simply perfect,with no issues whatsoever in the fit of part A to B.
With Belairs input, this has helped me achieve rapid process to the point at 18.1.15, I have the entire airframe constructed in its initial phase.
The model will be finished as White 100 .
Last edited by Mike Booth on February 18th, 2015, 10:31 pm, edited 2 times in total.
Re: Yak 3-9 1/3 scale
Postby Mike Booth » January 18th, 2015, 8:34 pm
YAK3 white 100 based in the UK.
White 100
Postby Mike Booth » January 19th, 2015, 11:06 am
Fuselage
Just the bullet points for now as it's so time consuming resizing ever picture for this site.
Wings off the washout jigs.
Wing fuz fit. 19.1.15
Postby Mike Booth » June 19th, 2015, 7:04 am
Nearly there with everything built and painted.
Just fitting out.
Almost there...
rob ellis
Postby rob ellis » June 19th, 2015, 11:33 am
lovely mike,.,.,.have you thought about a composite kit of this,.,.,.,.?
Postby Mike Booth » June 20th, 2015, 7:33 am
Cheers Rob.
Yes that's likely to be born next year.
rob ellis
Postby rob ellis » June 20th, 2015, 9:01 am
good news,..,.,count me in,..,,
GrahamKennedy
Postby GrahamKennedy » June 20th, 2015, 11:59 am
Good to see a different subject - what is the projected weight?
Graham
Postby Mike Booth » July 3rd, 2015, 6:13 pm
Graham, I'm thinking around the 24kg mark.
Not sure yet as the motor weighs 4.5kg and I've yet to fit it.
Cheers. Mike.
Postby Mike Booth » September 7th, 2015, 7:16 pm
So after a fair break and more completion work on my MK 19 Spit, I've started the last push on the Yak.
Canopy made and fitted, I've purchased A 3W 150 inline twin, so no lack of beans in the performance.
I've just made a suitable carbon/Ali engine mount, so I've allowed myself a play at weathering.
The UC is finally under manufacturer after let downs.
Soon to be on wheels when I can take some good airframe pictures prior to fitting out.
All in good time.
Airshow active dirt.
Karl mander
Postby Karl mander » September 8th, 2015, 8:11 pm
Beautiful model Mike, looking forward to seeing it in the air.
24 kg is light, it's going to be a big floater. My 128" fairey firefly weighs in at 41kg.
Karl
Postby Mike Booth » September 9th, 2015, 8:00 am
Interesting Karl. I have the whole finished airframe to hand, so weighing individual parts pre servo fit will give me a good idea.
Trevor Wood
Postby Trevor Wood » September 10th, 2015, 2:12 pm
Hello Mike,
Congratulations on putting together a lovely rendition of an unusual type which I very much look forward to seeing in the flesh,I would be interested to know how you might be planning to cool the 3W engine in general, and the rear cylinder in particular,to be honest this is an area that has really always put me off going for a substantially sized warbird of this configuration,plus on the Yak there doesn't seem to be any evidence of a small chin cowl a la 'Mustang' to utilise,I see there are a couple of intakes at each wing root which might duct air forward but tricky or what.
Anything you can share here would be informative since I know you will not be satisfied with just cutting a dirty great hole in the bottom of the cowl.
Best regards Trevor
Postby Mike Booth » September 11th, 2015, 10:52 am
Trevor, good to hear from you and thanks for your interest and input.
In answer to your question, I plan to cut most of the cowling away to cool the motor :lol:
In fact you are right I have made use of the leading edge intakes to ram additional air over the rear cylinder.
I also have extensive baffling from a Yak7 chin intake I plan to fit.
Warm air exits low and into the wheel wells.
Watch this space.
Trevor Wood
Postby Trevor Wood » September 14th, 2015, 12:39 pm
Hello Mike,
Thanks for the reply,will look forward to seeing your solution,as you are fully aware the rear cylinder is the real problem here, the effective cooling of which will be mandatory on this big twin in order to avoid problems.
Keep the posts coming it's great to see a new heavy metal bird taking shape.
Cheers Trevor
Jason Griffiths
Postby Jason Griffiths » September 14th, 2015, 4:23 pm
Hello Mike - That's look good and coming on nicely 8-)
Thanks 8-)
Postby Mike Booth » January 31st, 2016, 8:32 pm
Here's Jon Horne looking rightly proud after completing his Airworld Yak 11 in matching team display colour scheme to an exemplary standard.
Moki 250 with powerbox and Futaba looking after the urge and the airwaves.
Yak 3 and Yak 11 soon to meet for photo shoot.
Beautiful Yak
Postby Mike Booth » January 31st, 2016, 8:41 pm
Nearly there....
david clarke
Postby david clarke » January 31st, 2016, 9:29 pm
Beutifull Mike,can't wait to see it fly.
rob ellis
Postby rob ellis » February 1st, 2016, 9:40 am
both get my vote;.;.
Users browsing this forum: No registered users and 51 guests
