4mm Aluminium Ball Links
Robert White
Postby Robert White » March 13th, 2015, 7:05 pm
Hi All,
Am failing to locate 4mm bore and M4 thread aluminium ball links with standoffs that allow a 30 degree lateral movement. There are a lot of aluminium 4mm ball links out there but none that I can find with the standoffs. Any ideas where I might find some?
Thanks for any thoughts
Bob
steve stuttard
Re: 4mm Aluminium Ball Links
Postby steve stuttard » March 13th, 2015, 8:58 pm
what about using flat washers
Robert White
Postby Robert White » March 14th, 2015, 8:01 am
Hi Steve,
Problem with washers is that they restrict the lateral movement. The point of the standoffs is that they allow the movement. Not sure 'standoff' is a generally used term. This is where the ball has small tubes or sleeves attached to either side so that a reasonable distance is created between the ball and the surface to which the link is attached. This creates a space for the lateral movement.
Bob
Postby Alan Cantwell 1131 » March 14th, 2015, 9:53 am
I know what you mean, but the biggest i use are kavans, these have a 3 mm hole and thread, i think you need to look at the large quality petrol car guys, rossendale cobra models deal those,
Robert White
Postby Robert White » March 14th, 2015, 4:09 pm
Hi Alan,
Thanks for the thought but still drawing a blank. Think I'll just have to go with M3.
Bob
GordonTarling
Postby GordonTarling » March 14th, 2015, 5:42 pm
Surely you could find some short brass or aluminium 4mm spacers and some longer 4mm bolts? I've done this a few times with 3mm ball links and can't see it being a problem with 4mm ones.
Robert White
Postby Robert White » March 15th, 2015, 9:09 am
Hi Gordon,
The links I purchased (without thinking this through) are free to leave the housing so this means that when in position with the spacers the housing can still leave the ball and under some conditions bind. So the short tube approach will work if I can find ball links that securely hold the ball within the housing.
Bob
Postby Phil Clark » March 15th, 2015, 10:44 pm
I had some M4 'Rod Ends' from RS several years ago.........not cheap but superb quality.
http://uk.rs-online.com/web/p/rod-ends/0382302/
Robert White
Postby Robert White » March 16th, 2015, 8:33 am
Thanks for that Phil,
I had spotted those but the lateral movement is only +/- 13 degrees and I need at least 30 degrees. I have 3mm links which will be adequate so I'll just get on with those I think.
Bob
Nigel Cox
Postby Nigel Cox » March 16th, 2015, 11:27 am
Doesn't list the angle range ??http://hobbyking.com/hobbyking/store/__13101__M4_Alloy_Ball_Joint_5pcs_bag_.html?strSearch=M4%20ball
Robert White
Postby Robert White » March 16th, 2015, 11:30 am
Thanks Nigel I'll take a look
B
Mike altham
Postby Mike altham » March 19th, 2015, 12:33 pm
Robert White
Postby Robert White » March 19th, 2015, 3:23 pm
Hi Mike,
Thanks for responding. Having spent at least a day searching, I've visited all of these sites and more. Mike Reeves doesn't have any 4mm by the way. There's no shortage of ball links but not of the type that fits my needs. Hope you have better luck!
Bob
Chris Lane
Postby Chris Lane » March 19th, 2015, 6:59 pm
Try searching for M4 Rod Ends. This will bring you into karting/motor cycling/competition suppliers.
Robert White
Postby Robert White » March 20th, 2015, 3:56 pm
Thanks Chris but have looked there and most other places. Have decided to go with the M3 links I have. Just wanted an extra belt to go with my braces!
B
