Postby Phil Clark » June 20th, 2015, 3:54 pm
Hi Graham
It's well documented online, but YES PLEASE......the more photos & info the better. If they are e-mailable.......phil@fighteraces.co.uk.......or if you can put on a CD, mail it to the works address (address is on my website)
The Z is trundling on........the fuselage has basic rectangular balsa formers with diagonals added to stiffen. Before all the stringers go on, mounts have been added for the twin elevator & rudder servos......again, these have been moved from the plan location as 1) we'll need the tail weight with 20lb of Moki hung off the front & 2), we want all control linkages either hidden (elevator) as per the full-size, or closed loop cables exiting the fuz in the correct location (the rudder cables are shown incorrectly position on the plan). Access to these 3 servos will be via the canopy hatch with the pilots seat removed.
With these in, we've been on with adding the multitude of 9 x 3 Cyparis stringers in the outer formers (which are all added in 1/4's). The plan isn't the best so notches were cut in the 1st & last formers then a straight edge was used to determine the notch positions in the other formers to ensure they went in straight.
The cowl & spat patterns are also well on.......after glassing (4oz cloth & L285 resin), they were sprayed with a heavy coat of U-Pol 'Reface' (basically a sprayable version of P-38/U-Pol car body filler). This levels beautifully with 80/120 grit paper. After this, on with the KK epoxy primer......1st coat flatted with 120, 2nd with 240 etc etc.........these are now ready for a final coat and a 600 wet sand prior to applying a gloss coat ready for waxing/moulding.
- GeeBee-Z_13.jpg (46.17 KiB) Viewed 20711 times
- GeeBee-Z_15.jpg (44.07 KiB) Viewed 20711 times
- GeeBee-Z_18.jpg (46.8 KiB) Viewed 20711 times
- GeeBee-Z_19.jpg (53.06 KiB) Viewed 20711 times
- GeeBee-Z_20.jpg (49.5 KiB) Viewed 20711 times
- GeeBee-Z_17.jpg (33.53 KiB) Viewed 20711 times
